- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Westy
I have just installed the new mud USB point and getting the old one was a battle, solved with an air cut off disc in the end😃
I had an additional lighting supply to another switch on the back of the old and now wondering if I can still use it or need to find a new lighting circuit supply any help appreciated.
All sorted, working as it should as are the live switched circuit is working as it should happy days
4th Jun 2022 9:23pm |
glpinxit
I've been using a 'Baseus' plug-in charger for a few months now and it has been very good as well as avoiding some of the problems discussed above. It has the option of USB or USB-C and charges at up to 65W so it will cope with charging bigger stuff. But the main reason I bought it was that it has a digital voltage read-out and I got it in the winter when I was keen to ensure my battery was OK. Mine came from eBay (item eBay Item No. 393055352222 - you'll need to choose which variant you want) but they are also on Amazon. Cheers, Guy.
28th Jun 2022 9:06am |
Dinnu
As glpinxit. Why go through the hassle of replacing the 12V port? I have something very similar to this. Since technology is constantly changing, I already want to replace mine from 2x USB type A to one with a USB Type C.
https://www.aliexpress.com/item/1005002098756476.html
Once plugged in, it fits practically flush with the facia. I can also remove it and plug in any other 12V socket that I need. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
17th Jul 2022 6:43am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
