![]() | Home > Puma (Tdci) > Replace cigarette socket with USB |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
Had the centre console out to hardwire a dash cam today.
Whilst I was at Halfords getting supplies, I spotted this USB port thing: https://www.halfords.com/tools/fuses-elect...gJit_D_BwE The first review was someone with a defender rating it, so I bought one. I must have spent 30 mins wrestling the cigarette lighter out, for the Halfords one not to fit through the hole ![]() Has anyone used the Blue Sea ports? Do they fit through the hole? https://www.mobilecentre.co.uk/blue-sea-10...put-da4679 Cheers Stu 2011 CSW XS 90 |
I fitted the bluesea usb, apart from the wrestling to get the cigarette lighter out it was fine, no hassle at all . I just made up a tail to fit the original connector.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
These work well from Ian at IRB developments. USB-A and USB-C sockets
![]() Click image to enlarge > 110 XS Double Cab |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20751 ![]() ![]() |
BS for me too but a 12v socket. But a little enlargement if needed as suggested a round file or I used my Dremel with a little sanding drum on it. That’ll do the trick.
If you don’t want to modify the standard socket just add a mini connection loom in. I think if I recall it’s only 5.3mm standard spade terminals. Just made sure the cable dia is equal to or slightly larger than the standard. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Cheers for the responses
![]() That IRB one looks spot on. Hard to find any that have USB-c and charge at 3.6amp. 2011 CSW XS 90 |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 650 ![]() ![]() ![]() |
I have had to turn down the blue sea USB sockets on my myford lathe to get them to fit the three Pumas I have fitted them in to - they need a couple of mm taking off the outer rim to get them to sit properly in the recessed hole in the dash.
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge I recently bought the MUD UK USB charger socket that goes in the dash as a Land Rover switch. It has two wires, a RED one and a BLACK one. I presume I have to connect it to the back of the lighter socket that has three wires RED, BLACK and PURPLE. Does RED go to RED and BLACK to BLACK? Clueless as usual. Last edited by CharlieDonuts on 21st Feb 2021 4:47pm. Edited 1 time in total |
Yes, the purple/green will be illumination. Darren
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 226 ![]() ![]() ![]() |
Don’t want to contradict, but I think the red with yellow trace is illumination. Purple wth green is ignition switched power. Sorry if I’m wrong. Have you got a multi meter to check ?
Ashbyandy |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
Connect the small red wire on the Mud socket to the red/yellow wire to illuminate the USB when the lights are on
Need to cut the small red wire where it joins the large Red wire on the USB, otherwise it will be illuminated the whole time |
Ah, you're right! I should have engaged brain before keyboard. My mistake, sorry ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 21st Feb 2021 8:40pm. Edited 1 time in total |
No problems LRA, thanks for reply, 👍
Ashbyandy |
So like this
BLACK to BLACK RED to PURPLE Small RED to RED/YELLOW |
Yep, 👍
Ashbyandy |
