Home > Td5 > Re-chassis
Goldenballs
Re-chassis
Hi all,
Getting nervous about my 110 CSW chassis…
What kind of pennies should I expect to be spending? I’m not afraid to get stuck in and do it myself, but I am afraid of the time it would take…
Mike
Post #951967 8th May 2022 5:44pm
kenzle8a
I’ve budgeted about 5-7k for my diy Inc the chassis
Post #951968 8th May 2022 5:53pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
What else are you doing to make it that expensive?
The opportunities are endless with the body off Rolling with laughter 4.0 V8 Defender 90
My Instagram
Post #951969 8th May 2022 6:14pm
kenzle8a
A lot, I’ve budgeted to get a load of bits galvanised, replace all the brake lines with braided, as well as a few parts of the floor that need replaced and then painting etc. I’ve also budgeted to have the chassis painted at the upper end of the costs.
Post #951971 8th May 2022 6:18pm
JOW240725
I've had two seperate garages give me very budget costs at around £4-5k for THEM to do a chassis swap.
The end cost will vary considerable depending on what else you decide to replace along the way. I suspect it would be difficult to put anything rusty back onto a shiney new chassis and therefore guess the bill could go up as the replacement part list goes up. Thumbs Up James
Instagram @suffolk_rovers
Post #951973 8th May 2022 6:19pm
bodstruck
https://www.alpine-restorations.co.uk/galv...placement/
2 grand from these chaps. Not had any experience of them but at least they publish a price. Clearly will be more once you add on replacing all the stuff that will break in the process. Smile
Post #951977 8th May 2022 6:30pm
JOW240725
^^^ I assume those costs are the labour only and don't include the cost of the chassis? If so it puts them in the same ball park as my budgets.
Only heard good things about Alpine. Thumbs Up James
Post #951980 8th May 2022 6:36pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Says Labour only, in the price list Wink
It's all the extras that add up, springs, shocks, bolts, brackets etc
Also quite a price difference between Richards/Marsland chassis as well as the other cheaper brands...
We've fitted a few Richards, and they've been *OK*, a bit of faffing about to line everything up. The Marsland though are worth every extra penny, everything just fits Thumbs Up
Post #951981 8th May 2022 6:43pm
roel
I did it before and I can only say: It takes 2 x your planned budget and 3 x as much time or 3 x your budget and 2 x as much time depending if you refurbish or buy unplanned parts.
Once you start taking things apart you see more work.
Ok I changed from a diesel to a petrol V8 and having a first kid and building a house in between it took a bit more time, it took me about 3 years. Shocked Roel
2003 90 Td5 (2009-now)
Post #952007 8th May 2022 9:48pm
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
bodstruck wrote:
https://www.alpine-restorations.co.uk/galvanised-chassis-bulkhead-replacement/
I got a quote in writing last week from them to fit a new chassis .... the price was £5100.00
See below the extract from my quote:
Marsland Defender 90 300tdi chassis £2500.00
Chassis delivery £150.00
Consumables wd40/power steering fluid/brake fluid/antifreeze £150.00
Labour cost to fit chassis £1450.00
VAT £850.00
Estimated six weeks work.
Then you'll have to decide what NEW bits you'll add Exclamation 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #952009 8th May 2022 10:11pm
Retroanaconda
I re-chassised mine myself using the body off in one piece method and spent about £4k in parts/materials.
That’s the best way to keep the cost low, if you strip it right down you’ll find many more issues and spend much more.
Post #952022 9th May 2022 7:00am
plumpmoose
Just had mine done (Td5 90) and these numbers are about right. IE is fairly big spread depending on work done while chassis off.
Post #952046 9th May 2022 10:03am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Could you folks that have had a swap give us some examples of what extra work you have needed to have done. I am new to this so I am interested at what sort of things to expect. My chassis is 30 so it may be a future job!!
Post #952050 9th May 2022 10:44am
Retroanaconda
Amongst things that often need changed are all the suspension bushes, probably dampers if not fairly new, springs if rusty/worn, all fuel and brake lines, some of the wiring loom, potentially fuel tank, engine/transmission mounts, clutch.
Parts of the body can have significant rust and corrosion that is not evident until it is removed - e.g. bulkhead feet/footwells, sill members and b/c posts on 110s, seat box and rear tub mounting points. Any of these will add significantly to the cost and time required if they are to be dealt with.
It really depends how well the vehicle has been maintained over the years.
Post #952058 9th May 2022 12:16pm
Cubflyer
I would suggest this may be a good method for those born into engineering, having a good selection of tools, and the time and space to do it.
That I would suggest is not even 50 percent of the forum. 2010 Defender 90 300Tdi CW (White/1994)
Post #952064 9th May 2022 12:57pm
