Home > Technical > 110/130 brake upgrade
jst
Has anyone fitted upgraded brakes to a 110/130 on 16" rims. I see lof do a larger set for 18"s. I am after improving braking ability on my 130 which when loaded with camping kit and towing 2.5t stops well but just doesn't feel great. Braking system is 100% working as it should be. Thinking different pads as a start, mintex currently. It just doesn't have the bite that 110 has when similarly loaded Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #951645 5th May 2022 11:54am
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
I’ll be watching with interest as I have similar concerns. Are you sure the lof are for only 18s?
Mine again just doesn’t have the bite I would like, performed well on the brake test for the mot but I’m just not convinced.
First off I’m going to go for braided hoses all round, brake lines are original from 2008…!
Mechanic says stop whinging, she’s a heavy old girl….
Alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #951648 5th May 2022 12:14pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Have you looked at the LOF Clutches Power Spec brake kit? They specifically mention this for heavily laden 110/130. They do an Extreme spec too but you're looking at @£2k per axle for this and you'll need wheel spacers, but can retain your 16" wheels.
I'm not running these parts myself but they have received good feedback elsewhere.
Post #951650 5th May 2022 12:27pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Not done this on a Landy but on previous cars I've found that stainless steel braided brake lines and different pads make a difference. Additionally high temperature brake fluid.
I've previously used EBC Green Stuff pads and Castrol SRF brake fluid.
Post #951652 5th May 2022 12:33pm
kenzle8a
How much load are you needing to stop? I have the LOF road spec kit and the only time I've wanted more bite was with 3.4 tonnes of horse trailer behind the 110, its not that the kit is lacking, I'd just like a bit more so I'm going to fit the power spec pads.
Post #951662 5th May 2022 2:05pm
jst
I did look at power spec, just seems to be different pads and discs wondering if I don't need more. Extreme 16 and 18? Anyone tried them?
The 345mm set says 18" with spaces the calipers will go behind the rims then?
Already have braided hoses.
My 90 and 110 stop brilliantly, have exactly.same setup on 130, 130 is just heavy and whilst.it.stops better than.most defenders it doesn't stop as well as the other two. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #951664 5th May 2022 2:09pm
Likeomg
I have some big stoppers although on a 90…
360mm disc front 6 pot’s and need a 18” rim for them..
Rears
Post #951665 5th May 2022 2:11pm
bankz5152
LOF do a set for 16" but you need 30mm spacers Instagram @defender_ventures
Empire Tuning - Agent
Post #951677 5th May 2022 3:38pm
The Zee
I don't know if this helps, but I've had braided hoses, overhauled calipers, coupled with the LOF POWERspec pads & disc kit front and rear on my 110, 2.2 puma, and yes the breaking is more progressive, but not the upgrade I expected.
So was considering a 16" compatible upgrade for F & R - I know AP Racing make a set but the price Shocked Zaid-M
www.DefencePhotos.com
Post #951678 5th May 2022 3:46pm
Co1
Bowler do 16” as well but not cheap. Perhaps Wilwood?
Post #951691 5th May 2022 5:23pm
jst
spoken with Luke, just considering options. they may need spacers on the 16" which wont work for me.
Porny hasnt come back to me.
Bowlers ones are £4k alround and not sure on rim size needed.
anyone running lukes setup? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #951802 6th May 2022 3:18pm
bankz5152
I had Lukes 16" extreme set on my 110. Really happy with the quality, stopping power was certainly heavily increased. Only real option unless you want to spend a small fortune.
Only downside is pads are around £80 a pair but super easy to change. Instagram @defender_ventures
Post #951811 6th May 2022 5:50pm
kenzle8a
It’s a lot considering it’s just from Alcon when their kit for my Cooper s is nearly half the price.
Post #951836 6th May 2022 9:10pm
jst
Cheers. Think this is where I am at just need some different rims! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #952207 10th May 2022 6:54pm
