Home > Technical > 110/130 brake upgrade |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 724 |
I’ll be watching with interest as I have similar concerns. Are you sure the lof are for only 18s?
Mine again just doesn’t have the bite I would like, performed well on the brake test for the mot but I’m just not convinced. First off I’m going to go for braided hoses all round, brake lines are original from 2008…! Mechanic says stop whinging, she’s a heavy old girl…. Cheers Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
5th May 2022 12:14pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 317 |
Have you looked at the LOF Clutches Power Spec brake kit? They specifically mention this for heavily laden 110/130. They do an Extreme spec too but you're looking at @£2k per axle for this and you'll need wheel spacers, but can retain your 16" wheels.
I'm not running these parts myself but they have received good feedback elsewhere. |
5th May 2022 12:27pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 567 |
Not done this on a Landy but on previous cars I've found that stainless steel braided brake lines and different pads make a difference. Additionally high temperature brake fluid.
I've previously used EBC Green Stuff pads and Castrol SRF brake fluid. |
5th May 2022 12:33pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
How much load are you needing to stop? I have the LOF road spec kit and the only time I've wanted more bite was with 3.4 tonnes of horse trailer behind the 110, its not that the kit is lacking, I'd just like a bit more so I'm going to fit the power spec pads.
5th May 2022 2:05pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8025 |
I did look at power spec, just seems to be different pads and discs wondering if I don't need more. Extreme 16 and 18? Anyone tried them? The 345mm set says 18" with spaces the calipers will go behind the rims then? Already have braided hoses. My 90 and 110 stop brilliantly, have exactly.same setup on 130, 130 is just heavy and whilst.it.stops better than.most defenders it doesn't stop as well as the other two. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
5th May 2022 2:09pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2640 |
I have some big stoppers although on a 90…
360mm disc front 6 pot’s and need a 18” rim for them.. Click image to enlarge Rears Click image to enlarge |
5th May 2022 2:11pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2164 |
LOF do a set for 16" but you need 30mm spacers Instagram @defender_ventures
Empire Tuning - Agent |
5th May 2022 3:38pm |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
I don't know if this helps, but I've had braided hoses, overhauled calipers, coupled with the LOF POWERspec pads & disc kit front and rear on my 110, 2.2 puma, and yes the breaking is more progressive, but not the upgrade I expected.
So was considering a 16" compatible upgrade for F & R - I know AP Racing make a set but the price Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
5th May 2022 3:46pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
Bowler do 16” as well but not cheap. Perhaps Wilwood?
5th May 2022 5:23pm |
spoken with Luke, just considering options. they may need spacers on the 16" which wont work for me.
Porny hasnt come back to me. Bowlers ones are £4k alround and not sure on rim size needed. anyone running lukes setup? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th May 2022 3:18pm |
I had Lukes 16" extreme set on my 110. Really happy with the quality, stopping power was certainly heavily increased. Only real option unless you want to spend a small fortune.
Only downside is pads are around £80 a pair but super easy to change. Instagram @defender_ventures Empire Tuning - Agent |
6th May 2022 5:50pm |
It’s a lot considering it’s just from Alcon when their kit for my Cooper s is nearly half the price. |
6th May 2022 9:10pm |
Cheers. Think this is where I am at just need some different rims! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
10th May 2022 6:54pm |
