Home > Modifications & Maintenance (L663) > Black Arch above rear door
Defendit..
Netherlands
Just noticed, maybe an ( early X-Dynamic ) design try out from JLR, but I think it looks rather good.
Especially on the lighter colors.
You can save a black roof option by painting only the arch. Any thoughts ?
Post #864973 2nd Nov 2020 2:00pm
Tim in Scotland
As there are three panel joins up there it would be easy and neat to do as a black wrap. As mine is a 1sr Edition it came with a black arch Wink
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #864979 2nd Nov 2020 2:37pm
Defendit..
Netherlands
Picked up this mod yesterday.
Disassembled the 2 black corners,
Total of 4 M6 bolts (socket 10) under the arch.
Push upwards to release the metal clips from the arch.
Disassemble the 3rd breaklight with 10 Torx screws.
Have it wrapped locally in gloss black.
Everything in the same order re installed.
Result
 No Mud flaps for my 90.!
P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #949544 16th Apr 2022 7:53am
JOW240725
Looks good! Thumbs Up James
Instagram @suffolk_rovers
Post #949550 16th Apr 2022 8:19am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
That looks great and I may copy that Thumbs Up You mention that there are 4 bolts to remove the rear cover, I can see one either side that I have highlighted, where are the other two please?
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #949761 18th Apr 2022 4:17pm
Defendit..
Netherlands
1 visible as you already mentioned.
The other one is under the arch. , Did use a little extension socket.
The first 4 are actually the first 6 Torx screws of the middle part, remove that by wiggling and clip release.
Post #949814 19th Apr 2022 7:15am
Hairy Dan
Brilliant, thanks Bow down I was looking around the centre of the arch, no wonder I couldn't find them Laughing Embarassed Cheers Ian
Kielder 4x4 Safari
Post #949825 19th Apr 2022 9:28am
Defendit..
Netherlands
Back to white again - to remain more 'Farmer Spec' after the respray in Keswick Green
Still stand behind it for the lighter colors to wrap the rear arch black.
The new 20" white alloys 9013 would look lovely now on my car.. Very Happy No Mud flaps for my 90.!
Post #1050810 5th Nov 2024 2:53pm
LR Nuts
This is the wheel, looks like 18" steel, but they are 20" alloys.
Post #1050816 5th Nov 2024 4:02pm
ruben
Spain
Sorry for being off topic, but I can see that you are wearing Pirrelli SC AT+ 20”, if so could you comment on what size and if it is equivalent and there is no friction? And what load and speed values ​​they have? sorry I can't see it in the picture!! and I haven't found them here…
.. and by the way, nice car and Thanks Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1050828 5th Nov 2024 6:12pm
LR Nuts
White arch, white roof, with black spoiler.
Post #1050843 5th Nov 2024 8:03pm
LR Nuts
What if you had just sprayed the plastic rear pillars white ??? and maybe the rear light panel-over-lamps, white as well.
Post #1050845 5th Nov 2024 8:12pm
Defendit..
Netherlands
@Ruben
Thanks
Still on the 18" Pirelli AT+ 275/65 R18 No Mud flaps for my 90.!
Post #1050856 5th Nov 2024 10:18pm
