Home > Modifications & Maintenance (L663) > Black Arch above rear door |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
As there are three panel joins up there it would be easy and neat to do as a black wrap. As mine is a 1sr Edition it came with a black arch
Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
2nd Nov 2020 2:37pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 422 |
Picked up this mod yesterday.
Disassembled the 2 black corners, Click image to enlarge Total of 4 M6 bolts (socket 10) under the arch. Push upwards to release the metal clips from the arch. Disassemble the 3rd breaklight with 10 Torx screws. Click image to enlarge Have it wrapped locally in gloss black. Everything in the same order re installed. Result Click image to enlarge Click image to enlarge Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. Last edited by Defendit.. on 5th Nov 2024 3:39pm. Edited 3 times in total |
16th Apr 2022 7:53am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 |
Looks good! James
16th Apr 2022 8:19am |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1416 |
That looks great and I may copy that You mention that there are 4 bolts to remove the rear cover, I can see one either side that I have highlighted, where are the other two please?
Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
18th Apr 2022 4:17pm |
1 visible as you already mentioned.
The other one is under the arch. , Did use a little extension socket. Click image to enlarge Click image to enlarge The first 4 are actually the first 6 Torx screws of the middle part, remove that by wiggling and clip release. Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. Last edited by Defendit.. on 19th Apr 2022 11:36am. Edited 2 times in total |
19th Apr 2022 7:15am |
Brilliant, thanks I was looking around the centre of the arch, no wonder I couldn't find them Cheers Ian
19th Apr 2022 9:28am |
Back to white again - to remain more 'Farmer Spec' after the respray in Keswick Green
Still stand behind it for the lighter colors to wrap the rear arch black. Click image to enlarge The new 20" white alloys 9013 would look lovely now on my car.. No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
5th Nov 2024 2:53pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1122 |
This is the wheel, looks like 18" steel, but they are 20" alloys. |
5th Nov 2024 4:02pm |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 195 |
Sorry for being off topic, but I can see that you are wearing Pirrelli SC AT+ 20”, if so could you comment on what size and if it is equivalent and there is no friction? And what load and speed values they have? sorry I can't see it in the picture!! and I haven't found them here… .. and by the way, nice car and Thanks Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
5th Nov 2024 6:12pm |
White arch, white roof, with black spoiler. |
5th Nov 2024 8:03pm |
What if you had just sprayed the plastic rear pillars white ??? and maybe the rear light panel-over-lamps, white as well.
5th Nov 2024 8:12pm |
@Ruben
Thanks Still on the 18" Pirelli AT+ 275/65 R18 No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
5th Nov 2024 10:18pm |
