![]() | Home > Modifications & Maintenance (L663) > Black Arch above rear door |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
As there are three panel joins up there it would be easy and neat to do as a black wrap. As mine is a 1sr Edition it came with a black arch
![]() ![]() 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 436 ![]() ![]() |
Picked up this mod yesterday.
Disassembled the 2 black corners, ![]() Click image to enlarge Total of 4 M6 bolts (socket 10) under the arch. Push upwards to release the metal clips from the arch. Disassemble the 3rd breaklight with 10 Torx screws. ![]() Click image to enlarge Have it wrapped locally in gloss black. Everything in the same order re installed. Result ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. Last edited by Defendit.. on 5th Nov 2024 3:39pm. Edited 3 times in total |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Looks good!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
That looks great and I may copy that
![]() ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
1 visible as you already mentioned.
The other one is under the arch. , Did use a little extension socket. ![]() Click image to enlarge ![]() Click image to enlarge The first 4 are actually the first 6 Torx screws of the middle part, remove that by wiggling and clip release. ![]() Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. Last edited by Defendit.. on 19th Apr 2022 11:36am. Edited 2 times in total |
Brilliant, thanks
![]() ![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Back to white again - to remain more 'Farmer Spec' after the respray in Keswick Green
Still stand behind it for the lighter colors to wrap the rear arch black. ![]() Click image to enlarge The new 20" white alloys 9013 would look lovely now on my car.. ![]() ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1217 ![]() ![]() |
![]() This is the wheel, looks like 18" steel, but they are 20" alloys. |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 242 ![]() ![]() |
Sorry for being off topic, but I can see that you are wearing Pirrelli SC AT+ 20”, if so could you comment on what size and if it is equivalent and there is no friction? And what load and speed values they have? sorry I can't see it in the picture!! and I haven't found them here… .. and by the way, nice car and Thanks Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
![]() White arch, white roof, with black spoiler. |
What if you had just sprayed the plastic rear pillars white ??? and maybe the rear light panel-over-lamps, white as well.
@Ruben
Thanks Still on the 18" Pirelli AT+ 275/65 R18 No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
