Home > Maintenance & Modifications > Best wiper blades? *and washer upgrade?*
Page 2 of 2 <12
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
there are a few different bosch aerotwin blades in our size -
the AR13U - I got the recommendation from blacklandy and I had to hunt for them a bit. They are the best wiper blades I have found so far.
the AP340U was more available when i was shopping - they are perhaps more curved?
I have not tried them both, there must be some difference between blades of the right size which could explain the polarisation of opinions. I'm actually really curious about this because I fought the terrible wipers for years on this truck. Roaming around 🇳🇴🇨🇭
Post #945302 10th Mar 2022 3:02pm
I use the AR13U type and have had no issues with them (yet), they're much better than the standard blades. I do make sure however that the pivot and spring in the arm is free and lubricated - I've met many vehicles over the years where the pivot has become so stiff that there's next to no spring towards the screen.
Post #945305 10th Mar 2022 3:25pm
hank
Just checked my emails and the AR13U are the one I got a few years ago. Will check the spring and pivot Thumbs Up > 110 XS Double Cab
Post #945312 10th Mar 2022 3:50pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
^^ What Hank said. Will report back when I've had a chance to investigate
Post #945318 10th Mar 2022 4:23pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Gasket wrote:
EDIT: rather than start a new thread I may as well add it here...
Is there an accepted way of upgrading the washers (screenwash squirters) on the front and back screens? The factory ones seem to dribble a bit of fluid out and I've long thought about upgrading either the pump or nozzles. The only thing is that I really do like my stock-looking 90 and am not convinced that the fancy Optimill/Design Development - type billet ones are in keeping with the look.
EDIT #2: I've just seen a reference to the CSI washer jets in another thread: http://www.csiparts.co.uk/en-gb/collections/screen-wash-jets - half the price of Optimill and a little more standard looking.
So a set of new wiper blades as recommended above and a pair of CSI washer jets should provide a significant improvement to the front and back screens for about £190 delivered.
On the subject of weak washers, first thing to check is the non return valves in the washer pipes, they usually reside by the heater box in the wing where it meets the bulkhead. Follow the pipes as hey leave the pumps and eventually you'll come across the point where the pipe looks like it's been cut and joined. These valves can clog up and significantly reduce flow. The rear washer on my 110 is perfectly fine for what it's required to do, adequate flow and if correctly aimed gets to where it needs to.
For the fronts I added a second 'standard' nozzle into the blanked off holes in the bulkhead, again the standard pump provides more than adequate flow to give 4 strong steams of fluid into the far corners of the screen. I think the total cost for 2 new nozzles, pipe and T piece connector was about £14! I elected to fit two new ones because as predicted the old one cracked when I tried to remove it.
Post #945356 10th Mar 2022 10:19pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I also did this, works just fine, no need for anything fancy, hose and t piece easily available even from Halfords 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #945367 11th Mar 2022 6:57am
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
I have replaced with Bosch Twin 340U. Looks stock, inexpensive, works well.
Post #947882 3rd Apr 2022 2:44pm
L110CDL
I had enough of the aero twins not lasting on two accounts, so i only use these now
Very Happy Thumbs Up Clayton.
Keeper.
Post #948069 4th Apr 2022 8:34pm
The first set of Aeros I had lasted and performed really well, the other sets since seemed to have a reduced lifespan. KEEP CALM AND Drill ON
Post #948072 4th Apr 2022 8:38pm
roel
I use these:
http://www.secondlifecarparts.com/lr079891...9-rui.html
For this price I keep them in stock en replace them as soon as I think they get a bit worn.
I hate to use expensive wipers when the windscreen is full of mud and sand, with these I don't bother. Roel
2003 90 Td5 (2009-now)
Post #948308 6th Apr 2022 10:28am
Page 2 of 2 <12
