Home > Maintenance & Modifications > Best wiper blades? *and washer upgrade?* |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17279 |
I use the AR13U type and have had no issues with them (yet), they're much better than the standard blades. I do make sure however that the pivot and spring in the arm is free and lubricated - I've met many vehicles over the years where the pivot has become so stiff that there's next to no spring towards the screen.
10th Mar 2022 4:25pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2285 |
Just checked my emails and the AR13U are the one I got a few years ago. Will check the spring and pivot > 110 XS Double Cab
10th Mar 2022 4:50pm |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 375 |
^^ What Hank said. Will report back when I've had a chance to investigate
10th Mar 2022 5:23pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 312 |
On the subject of weak washers, first thing to check is the non return valves in the washer pipes, they usually reside by the heater box in the wing where it meets the bulkhead. Follow the pipes as hey leave the pumps and eventually you'll come across the point where the pipe looks like it's been cut and joined. These valves can clog up and significantly reduce flow. The rear washer on my 110 is perfectly fine for what it's required to do, adequate flow and if correctly aimed gets to where it needs to. For the fronts I added a second 'standard' nozzle into the blanked off holes in the bulkhead, again the standard pump provides more than adequate flow to give 4 strong steams of fluid into the far corners of the screen. I think the total cost for 2 new nozzles, pipe and T piece connector was about £14! I elected to fit two new ones because as predicted the old one cracked when I tried to remove it. Click image to enlarge |
10th Mar 2022 11:19pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
I also did this, works just fine, no need for anything fancy, hose and t piece easily available even from Halfords 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
11th Mar 2022 7:57am |
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 123 |
I have replaced with Bosch Twin 340U. Looks stock, inexpensive, works well.
3rd Apr 2022 3:44pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10718 |
I had enough of the aero twins not lasting on two accounts, so i only use these now
Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
4th Apr 2022 9:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20214 |
The first set of Aeros I had lasted and performed really well, the other sets since seemed to have a reduced lifespan. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
4th Apr 2022 9:38pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I use these:
http://www.secondlifecarparts.com/lr079891...9-rui.html For this price I keep them in stock en replace them as soon as I think they get a bit worn. I hate to use expensive wipers when the windscreen is full of mud and sand, with these I don't bother. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
6th Apr 2022 11:28am |
