![]() | Home > Technical > Will Jeep LED headlights fit in a landy? |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 827 ![]() ![]() ![]() |
If they are the 7” ones yep Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3694 ![]() ![]() ![]() |
Yes they are. These are the ones: http://www.jwspeaker.com/products/jeep-led...eadlights/
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2134 ![]() ![]() |
Are they CE approved, can’t see it on the site. Can see USA and Canada stds but not ECE, so worth checking.
DOT & Transport Canada compliant for on-road use
Exactly what I was going to say need to be European valid ones. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Looked in more detail, They do have ECE approved ones, you can see the part numbers lower on the page. So just need to ensure you get the right one.
Yep, they are DOT approved, not ECE. Is that an MOT fail?
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2186 ![]() ![]() ![]() |
Why not just get the legal LR ones or are they $$ or something??
Yep, they’re second hand and a good price.
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 515 ![]() ![]() ![]() |
Would the light beam be correct for RHD
No they aren’t as it turns out Shane, so it’s a no good. Wanted ad posted on here instead!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
I was just going to say, you need to make sure they aren’t LHD as that’s standard across the pond where as ours are RHD beam.
About time EC regs are abolished and DOT markings applicable in tandem. So long as US versions are in RHD and DOT marked I’d have no hesitation in using them. Something that should be worked upon in my opinion. I have seen RHD versions for sale in the USA but you’d always have to double check. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Trinbagoman Member Since: 10 May 2022 Location: UK Posts: 4 ![]() ![]() |
Thanks, i have a set from a Jeep that i am thinking of fitting.
