Home > Technical > Will Jeep LED headlights fit in a landy? |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 813 |
If they are the 7” ones yep Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
20th Mar 2022 5:43pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3667 |
Yes they are. These are the ones: http://www.jwspeaker.com/products/jeep-led...eadlights/
20th Mar 2022 5:56pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1972 |
Are they CE approved, can’t see it on the site. Can see USA and Canada stds but not ECE, so worth checking.
20th Mar 2022 6:09pm |
DOT & Transport Canada compliant for on-road use
Exactly what I was going to say need to be European valid ones. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
20th Mar 2022 6:12pm |
Looked in more detail, They do have ECE approved ones, you can see the part numbers lower on the page. So just need to ensure you get the right one.
20th Mar 2022 6:32pm |
Yep, they are DOT approved, not ECE. Is that an MOT fail?
20th Mar 2022 7:04pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2132 |
Why not just get the legal LR ones or are they $$ or something??
20th Mar 2022 7:38pm |
Yep, they’re second hand and a good price.
20th Mar 2022 8:15pm |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 496 |
Would the light beam be correct for RHD
21st Mar 2022 12:11pm |
No they aren’t as it turns out Shane, so it’s a no good. Wanted ad posted on here instead!
21st Mar 2022 6:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20282 |
I was just going to say, you need to make sure they aren’t LHD as that’s standard across the pond where as ours are RHD beam.
About time EC regs are abolished and DOT markings applicable in tandem. So long as US versions are in RHD and DOT marked I’d have no hesitation in using them. Something that should be worked upon in my opinion. I have seen RHD versions for sale in the USA but you’d always have to double check. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
21st Mar 2022 7:44pm |
Trinbagoman Member Since: 10 May 2022 Location: UK Posts: 4 |
Thanks, i have a set from a Jeep that i am thinking of fitting.
10th May 2022 5:32pm |
