Home > Technical > Will Jeep LED headlights fit in a landy?
Co1
As above. Will a set of aftermarket JW Speaker headlights that are from a Jeep Wrangler fit in a defender?
Col
Post #946370 20th Mar 2022 5:19pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
If they are the 7” ones yep Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #946373 20th Mar 2022 5:43pm
Co1
Post #946377 20th Mar 2022 5:56pm
Ianh
Are they CE approved, can’t see it on the site. Can see USA and Canada stds but not ECE, so worth checking.
Post #946382 20th Mar 2022 6:09pm
Race.it
DOT & Transport Canada compliant for on-road use
Exactly what I was going to say need to be European valid ones. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #946383 20th Mar 2022 6:12pm
Ianh
Looked in more detail, They do have ECE approved ones, you can see the part numbers lower on the page. So just need to ensure you get the right one.
Post #946387 20th Mar 2022 6:32pm
Co1
Yep, they are DOT approved, not ECE. Is that an MOT fail?
Post #946394 20th Mar 2022 7:04pm
90 Dreamer
Why not just get the legal LR ones or are they $$ or something??
Post #946398 20th Mar 2022 7:38pm
Co1
Yep, they’re second hand and a good price.
Post #946404 20th Mar 2022 8:15pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Would the light beam be correct for RHD
Post #946462 21st Mar 2022 12:11pm
Co1
No they aren’t as it turns out Shane, so it’s a no good. Wanted ad posted on here instead!
Post #946508 21st Mar 2022 6:05pm
I was just going to say, you need to make sure they aren’t LHD as that’s standard across the pond where as ours are RHD beam.
About time EC regs are abolished and DOT markings applicable in tandem.
So long as US versions are in RHD and DOT marked I’d have no hesitation in using them.
Something that should be worked upon in my opinion.
I have seen RHD versions for sale in the USA but you’d always have to double check. KEEP CALM AND Drill ON
Post #946515 21st Mar 2022 7:44pm
Trinbagoman
Monaco
Thanks, i have a set from a Jeep that i am thinking of fitting.
Post #952190 10th May 2022 5:32pm
