Home > Td5 > Really sluggish acceleration |
Jordan Member Since: 08 Jan 2022 Location: Leicestershire Posts: 49 |
Thanks, just tried the 4th gear 25mph test, starts to pick up around 35-40mph
27th Feb 2022 5:00pm |
Ordered myself a Nanocom, so I can see what is happening. I did find the Waste gate actuator rod was set at 15 threads, so altered that by a couple, feel it boosting now lower down, but still pants on the top end.
I also noted on my run out last weekend, which was 80miles round trip I used over half a tank of fuel. |
2nd Mar 2022 7:50pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2758 |
Look on the bright side, at least if it gets stolen the rozzers will be able to catch it
3rd Mar 2022 4:14pm |
Yeah and on foot
3rd Mar 2022 4:15pm |
Bought myself a Nanocom unit.
Anyone on here no what readings I should be getting and when, so I can have some references. |
7th Mar 2022 11:41am |
Just been for a run.
I have the following fault codes up 4.3 coolant temperature circuit Logged high 6.3 coolant temperature circuit, current 10.1 Air Conditioning Fan Drive open load 10.3 Tachometer Drive Open Load, current 10.4 Gearbox/ ABS open Load, logged 10.5 Air conditioning Clutch Drive , logged 14.1 Air Conditioning Fan Drive Open, current 14.3 Tachometer drive open load, current 14.4 Gearbox/ ABS drive Open load, current 14.5 Air Conditioning Clutch Drive, current 24.7 Problems detected with Auto gearbox, current The coolant level is full, I bled it off last week, it never gets above the halfway mark, nanocom gave me a high of 88 while out. It does not have air conditioning or ABS or Automatic Gearbox. While out driving in 4th gear I can get max 3600 rpm and that give me 0.9bar of boost. |
7th Mar 2022 1:51pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 317 |
Has it had a new ECU salvaged from a Disco one wonders?
Might be time to talk to someone who understands Td5 ECUs? |
7th Mar 2022 4:26pm |
All the air conditioning, tachometer and ABS faults can be ignored as these are likely not fitted to your Defender unless it's the XS version (half leather seats)
The auto gearbox is a bit odd and could mean you've got the wrong ECU |
7th Mar 2022 5:08pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 617 |
Focus on fault 6.3, it looks like, it has no valid engine temperature values. Look for live data and compare temperature values with "reality" of engine. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
7th Mar 2022 5:11pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
If you have the original ECU you should have a sticker with your vin-number on it.
Does your temperature gauge shows normal temperature as I believe an ECU programmed for a disco won't work correctly with a Defender temp gauge. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
7th Mar 2022 8:17pm |
Disco ECU in Defender results in wrong working temperature gauge (needle is going in opposite way), but only the gauge, not ECU, because temperature sensor is the same. Much worse is bad habbit of gas pedal, it works like a "switch", on road it is ussable, but off road it is wery hard to controll engine power.
WIN is also written in the ECU software, but it is only for evidence and only in newer NNN type ECUs. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
8th Mar 2022 6:02am |
lt's got to be something like that, he's tried everything else!
When the ECU failed in my 110 the garage fitted a Disco one to get it moving and it did run, but there was no power and the gas pedal didn't work properly, as described above. |
8th Mar 2022 8:23am |
Temperature gauge does up to just under half when in use. The Nanocom gave me a digital display of 88degrees yesterday.
I will check the ECU today. |
8th Mar 2022 8:34am |
Just checked the ECU, all plugs are clean, there is a sticker (not LR) stating the chassis number, using the Nanocom it rear the VIN of it and it corresponds to my log book.
8th Mar 2022 9:39am |
