Home > Puma (Tdci) > 2011 puma 110 rear drive shaft
Alex123
Scotland 2011 Defender 110 2.5 TD HT Baltic Blue
Hi lads where can I buy a new rear drive shaft for 110 puma 2011 rear joint has play and on inspection the sockets are worn also thanks to last owner
Alex
Post #944348 2nd Mar 2022 1:18pm
Advanced Factors
Site Sponsor
United Kingdom 1994 Defender 90 V8 Petrol SW Corris Grey
Hi Alex.
Please use the link below to our website.
https://www.advancedfactors.co.uk/rear-hub...0935-c.asp
I'm guessing you will either need part numbers
TOB500020 RH SHAFT
TOB500030 LH SHAFT
RUC105200 FLANGE(S)
571752 GASKET
Regards Paul. Paul Redding
+44 (0)23 8052 2760
Site Sponsor for Aftermarket Parts
Post #944351 2nd Mar 2022 1:49pm
Alex123
Thanks Paul
Post #944352 2nd Mar 2022 1:51pm
gcc130
It’s worth considering single piece shafts, eliminating one wear point.
I think Britpart are as good as any, but stand to be corrected.
Post #944385 2nd Mar 2022 7:42pm
Re: 2011 puma 110 rear drive shaft
Alex
Do you mean rear prop shaft or rear half shafts?
Post #944389 2nd Mar 2022 7:55pm
Alex123
Rear prop shaft
Post #944392 2nd Mar 2022 8:25pm
Alex123
Ok thanks
Post #944394 2nd Mar 2022 8:26pm
gcc130
Sorry I thought you meant half shaft , not prop shaft, please ignore my post🙂
Post #944396 2nd Mar 2022 8:30pm
Ianh
Check out Gwyn Lewis offerings as well.
https://gwynlewis4x4.co.uk/?s=Prop&post_type=product
Post #944401 2nd Mar 2022 8:53pm
Shame you are so far away, I have a spare which is surplus to requirements. Sad
Post #944422 2nd Mar 2022 11:33pm
smb
Got mine from Gwyn Lewis. Don’t forget to get a set of UJ nuts & bolts for the front and another for the rear. The front are shorter than the rear. Don’t rely on a LR dealer to get it right. Had a nightmare with Chester dealer as the parts lists they work on state that they are the same when they are not!!
Post #944423 2nd Mar 2022 11:50pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Gratuitous picture of one of my gwyn Lewis props.
Not cheap, but I can’t fault them.
 2002 td5 90 county hardtop
Post #944429 3rd Mar 2022 7:32am
