Home > Puma (Tdci) > 2011 puma 110 rear drive shaft |
Advanced Factors Site Sponsor Member Since: 06 Jun 2013 Location: Southampton Posts: 178 |
Hi Alex.
Please use the link below to our website. https://www.advancedfactors.co.uk/rear-hub...0935-c.asp I'm guessing you will either need part numbers TOB500020 RH SHAFT TOB500030 LH SHAFT RUC105200 FLANGE(S) 571752 GASKET Regards Paul. Paul Redding +44 (0)23 8052 2760 www.advancedfactors.co.uk Site Sponsor for Aftermarket Parts |
2nd Mar 2022 1:49pm |
Alex123 Member Since: 11 Dec 2020 Location: Argyll Posts: 24 |
Thanks Paul
2nd Mar 2022 1:51pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 739 |
It’s worth considering single piece shafts, eliminating one wear point.
I think Britpart are as good as any, but stand to be corrected. |
2nd Mar 2022 7:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
Do you mean rear prop shaft or rear half shafts? |
2nd Mar 2022 7:55pm |
Rear prop shaft
2nd Mar 2022 8:25pm |
Ok thanks |
2nd Mar 2022 8:26pm |
Sorry I thought you meant half shaft , not prop shaft, please ignore my post🙂
2nd Mar 2022 8:30pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2005 |
Check out Gwyn Lewis offerings as well.
https://gwynlewis4x4.co.uk/?s=Prop&post_type=product |
2nd Mar 2022 8:53pm |
Shame you are so far away, I have a spare which is surplus to requirements.
2nd Mar 2022 11:33pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Got mine from Gwyn Lewis. Don’t forget to get a set of UJ nuts & bolts for the front and another for the rear. The front are shorter than the rear. Don’t rely on a LR dealer to get it right. Had a nightmare with Chester dealer as the parts lists they work on state that they are the same when they are not!!
2nd Mar 2022 11:50pm |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 377 |
Gratuitous picture of one of my gwyn Lewis props.
Not cheap, but I can’t fault them. Click image to enlarge 2002 td5 90 county hardtop |
3rd Mar 2022 7:32am |
