Home > Puma (Tdci) > I presume this is normal ?
rossy
just back from a 200 mile round trip where I really gave it some welly - more than ever before now its done about 4k miles. Also noticed the 'puma rattle' that I mentioned on an earlier post which had disappeared has now returned. Censored . Nicknick said its probably a slightly out injector timing and I think he's right but also I think the 2 stroke oil has slightly changed the combustion properties of the diesel too but thats another story.
Anyway after I returned I was just revving it while stationary and I noticed it would not rev above 3000 rpm foot to the floor. I presume this is an ECU thing to stop unnecessary wear and silliness but I thought I'd better ask since I never noticed before. Is this the case or is something not right ? Confused
Post #94429 15th Oct 2011 8:37pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
could be the MAF sensor packing up? BM52
Post #94431 15th Oct 2011 8:41pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Well ... not sure with Defenders [never tried], but i work on Transits every day and they wont rev above 3000rpm in neutrel either [unless you depress the clutch too]
so i'd assume its normal on the Defender.
Will try it with mine tomorrow Guns and Landrovers .... anything else is irrelevant.
Post #94434 15th Oct 2011 8:54pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
did you have foot on clutch, even if slight pressure is on clutch or in gear with clutch down, then there is a rev limiter to save prem clutch wear.
Post #94473 16th Oct 2011 8:10am
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
I prefer to call it Launch Control Wink
Although I don't think the gearbox would survive dumping the clutch at 3000rpm....
Post #94523 16th Oct 2011 3:47pm
spudfan
Ireland
"I think the 2 stroke oil has slightly changed the combustion properties of the diesel too but thats another story"
For better or for worse? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #94533 16th Oct 2011 4:53pm
rossy
I don't really know, Spud. Its all total conjecture on my part. I use the 2SO because in my experience with my last car it keeps the internals (turbo vanes, MAP sensor, EGR etc )clean and because for much of the time its short journeys and cold starts for the 110 thats why I use it. The rattle stopped for a while during which time I was intermittantly using JASO FB but for the last couple of weeks after I cracked open the Castrol Actevo which is FC (and used it at each fill since) its got noisy again thats why I thought there may be some correlation between the two.
I remember Nicknick said that due to manufacturing tolerances between batches of engine components the injection timing even if out by 1/4 of a degree can cause the rattle and can be adjusted on a laptop. I'm assuming that the differing burning characteristics of derv/2SO compared to just derv is enough to exascerbate whatever the status quo of my particular timing set up is. Bloody hell that sounds like poppycock but today I filled up with me normal Topaz diesel with no 2SO added so I'll soon know if thats the case.
Funnily enough my father in law's 1 year old 90 is a rattly one too so I suppose thats just how some of them come out of the box
Post #94588 16th Oct 2011 7:47pm
