![]() | Home > Td5 > Coolant leak |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Sure it’s not the screw in plug under exhaust manifold?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
What screw under the manifold? 1999 Defender TD5 110
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
Here’s a coolant parts diagram. https://www.lrworkshop.com/diagrams/land-r...oses_52976
I’d also consider looking harder at the screw plug and the three frost plug things under the manifold. ![]() ![]() Click image to enlarge ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Yah, that one too! :-0 2010 Range Rover MkIII Autobiography Super Charged (Idris)
The one I have pic’d leaked on my Td5 and showed under turbo, but looks dry screw plug looks dry as heat from manifold dries it. Much easier to spot if no heat shield and/or no webbing in exhaust manifold like I now run.
Cheers for the picture that makes it easier to locate now I know were I am fondling!
After another look and use of my mobile phone, my initial suspect, the pipe does show some pink staining on one of the spring clip (as you look from the passenger side wing, its the left hand spring clip. Pesky turbo and heat shield are in the way! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
@4RF RDS which website is the exploded picture of the engine from? 1999 Defender TD5 110
Like it says 99 MY workshop manual. If you want a pdf version PM me a valid email address and I’ll send a copy to you. Or go here… https://ovlr.ca/2021/09/04/defender-resources/
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thanks for the link
![]() Regards John M0VAZ Econet Station 48 no clock |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Did you get it sorted John?
Update: Took the 110 to my local garage and they found the rubber pipe had a pin hole and was leaking from there. Pipe now replaced. Fingers crossed! 1999 Defender TD5 110
Also worth noting, one end of the pipe is wider than the other end. 1999 Defender TD5 110
Good result ![]() |
