Home > Td5 > Coolant leak
excossack
Coolant leak
Spotted a coolant leak... Well more of a coolant pool on the floor after a 20min run down the motorway.
Traced the coolant leak to the area under the turbo(pooling on the little ledge under the turbo). There appears to be a rubber hose just under/around the turbo area that links two metal pipes, one of which comes across from the back of the head. I think its this pipe that is leaking,
Trying to find a parts diagram that shows this pipe to get a better idea. Any ideas? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #944035 27th Feb 2022 6:56pm
landy andy
Sure it’s not the screw in plug under exhaust manifold?
Post #944037 27th Feb 2022 7:11pm
excossack
What screw under the manifold? 1999 Defender TD5 110
Regards
John M0VAZ
Post #944045 27th Feb 2022 9:04pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Here’s a coolant parts diagram. https://www.lrworkshop.com/diagrams/land-r...oses_52976
I’d also consider looking harder at the screw plug and the three frost plug things under the manifold. Thumbs Up
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #944053 27th Feb 2022 9:30pm
landy andy
Post #944055 27th Feb 2022 10:09pm
4RF RDS
Yah, that one too! :-0 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #944058 27th Feb 2022 10:42pm
landy andy
The one I have pic’d leaked on my Td5 and showed under turbo, but looks dry screw plug looks dry as heat from manifold dries it. Much easier to spot if no heat shield and/or no webbing in exhaust manifold like I now run.
Post #944062 27th Feb 2022 11:30pm
excossack
Cheers for the picture that makes it easier to locate now I know were I am fondling!
After another look and use of my mobile phone, my initial suspect, the pipe does show some pink staining on one of the spring clip (as you look from the passenger side wing, its the left hand spring clip.
Pesky turbo and heat shield are in the way! 1999 Defender TD5 110
Regards
John M0VAZ
Post #944079 28th Feb 2022 9:20am
excossack
@4RF RDS which website is the exploded picture of the engine from? 1999 Defender TD5 110
Regards
John M0VAZ
Post #944080 28th Feb 2022 9:31am
4RF RDS
Like it says 99 MY workshop manual. If you want a pdf version PM me a valid email address and I’ll send a copy to you. Or go here… https://ovlr.ca/2021/09/04/defender-resources/ Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #944132 28th Feb 2022 5:33pm
excossack
Thanks for the link Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #944163 28th Feb 2022 8:31pm
Screbble
Did you get it sorted John?
Post #944698 5th Mar 2022 10:57am
excossack
Update: Took the 110 to my local garage and they found the rubber pipe had a pin hole and was leaking from there. Pipe now replaced. Fingers crossed! 1999 Defender TD5 110
Regards
John M0VAZ
Post #944991 7th Mar 2022 11:36pm
excossack
Also worth noting, one end of the pipe is wider than the other end. 1999 Defender TD5 110
Regards
John M0VAZ
Post #945029 8th Mar 2022 11:20am
Screbble
Good result Thumbs Up
Post #945075 8th Mar 2022 6:27pm
