Home > Tdi > New to forum …. 300tdi oil leak top of engine
NFIN02
United Kingdom 1989 Defender 90 300 Tdi HT Chawton White
Hi all- I am new to forum and defenders. Got my first one just yesterday, 300tdi 90. Discovered this oil leak any ideas?? Thanks
Post #942892 17th Feb 2022 9:10pm
NFIN02
Post #942893 17th Feb 2022 9:10pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
Sure it’s oil and not diesel the rubber fuel return pipes perish and leak
Post #942895 17th Feb 2022 9:18pm
donmacn
As far as Tdi oil leaks go, that doesn’t look too bad at all tbh. Engine looks pretty clean.
The cyclonic separator - the small canister thing in the middle of your pics (apols if you know that already) - would come off by loosening a couple of jubilee clips, and then one longer bolt into the rocker cover. If you took it off you’d get a clearer idea what’s happening in there.
It could be that either of the hoses attached to it are leaking.
There’s an O ring around the spigot/pipe where the separator fits into the rocker cover - could be gone?
Or it could be that there’s a bit of back pressure in the head/rocker cover pushing oil through.
But at least with the separator off, you’d see more clearly.
Try Googling 2 things - one is the separator itself so that you can see a pic of it, and understand how it slots into the rocker cover (it’s just a bit of plastic, so always a risk of breaking it). Or just order and fit a new one - they’re pretty rubbish anyway.
Second thing would be 300Tdi back pressure - you’ll find videos (at least one on here) - showing that if you remove the oil filler cap, and just sit it in place, it might dance about a lot if there’s too much crank pressure coming through into the head. I’d say that’s a lot less likely though. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #942898 17th Feb 2022 9:41pm
NFIN02
Thanks for the advice. There was a small puddle (2-3inch) on garage floor this morning and followed it up to that area.will get a better look tomorrow. Underneath all dry and in good order so this stood out for me.
Post #942900 17th Feb 2022 9:51pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Worth looking at these as they do perish. They also normally do not sit underneath the acoustic cover, as they are in the picture, so they may be squashed and split, 5 mins to replace if needed.
Post #942903 17th Feb 2022 10:16pm
Smell it, easily identified if it’s diesel.
Post #942904 17th Feb 2022 10:16pm
NFIN02
Put a sheet of cardboard under engine last night. Small 2 inch circular puddle this morning. More Photos added from underneath … definitely oil 🤔
Post #942967 18th Feb 2022 2:48pm
NFIN02
Post #942971 18th Feb 2022 3:14pm
NFIN02
Post #942992 18th Feb 2022 7:07pm
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
Think I have the same issue on my tdi 300 - I have a very small drip - literally 2 drips when turning the engine off after a long drive, mine is the seal on the transfer box - very easy to sort but a nightmare to get at so not worth doing.
Yours looks similar - be pleased its a small drip as Ive seen tai's with multiple heavy oil leaks all over.
Post #943033 19th Feb 2022 11:50am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Also worth a look at the lft pump.
Mine leaks onto the block and it then runs down to the gearbox.
On short trips, 2 or 3 km, it will drip on the floor but not on longer trips.
Heat must have some kind of effect.
Post #943039 19th Feb 2022 1:10pm
Dinnu
Top of the engine could be the top cover gasket. Very easy fix.
Last picture shows some oil coming out from the belhousing wading plug hole. Judging by the colour, it looks like engine oil (gearbos input shaft leak can show through there too). If that is the case, then most likely is the rear crankshaft seal, which is an engine or gearbox out to replace. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #943083 19th Feb 2022 6:23pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
And don’t forget to check the vacuum pump cover plate joint, it’s a common leak point 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #943116 20th Feb 2022 5:55am
NFIN02
Will check this - many thanks much appreciated
Post #943131 20th Feb 2022 9:27am
