![]() | Home > Puma (Tdci) > Service kits: Britpart vs OEM vs Genuine |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1312 ![]() ![]() ![]() |
I use Advanced Factors - sponsor on here. Good price and decent Mahle stuff or equivalent.
For oil I get Castrol from Costco |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4248 ![]() ![]() ![]() |
Avoid the Mahle oil filters, they have paper ends instead of plastic. Avoid the Mann oil filters, they have incorrect bore size and don’t seat properly. Genuine are not that expensive and you know it’ll be right. You can probably save a couple of quid by using a Ford branded one for a Transit.
Make sure your air filter box lid is reseated properly after putting a new filter in. It is very easy to miss the hooks under the wing. Don’t forget to give the prop shafts a bit of grease. 2007 110 TDCi Station Wagon XS |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3659 ![]() ![]() ![]() |
not britpart, was once sent a britpart sump plug as part of a Genuine kit!! and it cost me 7 litres of castrol as the seal basically didnt, I now buy ford engine parts from my local ford dealer DEFENDER 90 TDCI XS,
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
We buy parts for our Rivus workshops from ECP but for service parts find that OEM service items are as cheap if not more so, and you know they are correct.
For non service items there are some good aftermarket cost effective solutions and in many cases they are better than OEM From my experience Dealers try to keep basic services competitive to stop you using an independent garage, they make their margins on other items and repairs. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT Last edited by Leamreject on 13th Feb 2022 4:14pm. Edited 1 time in total |
ksv Member Since: 04 Nov 2014 Location: Volgograd Posts: 19 ![]() ![]() ![]() |
I use oil filter from Purflux, the herringbone form gives more filtration area.
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 250 ![]() ![]() ![]() |
I had a britpart kit for the l322 range rover and everything was perfect.
but for the defender i have only ordered parts here and there individually - sump plug which was fine, and oil filter which looks almost identical to the genuine ford one when sat side by side. 1953 80" 1987 mini city e 2011 90" |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20643 ![]() ![]() |
Genuine gets my vote, because it’s critical parts you don’t want issues to crop up with.
It’s just annoying and a pain to possibly have problems crop up that needn't be a problem. I would can use Ford Genuine parts at times too, that would be good enough as well. Engine oil in mine is Fuchs, and axles + T box. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2299 ![]() ![]() ![]() |
Hello MSmith7069
I Service mine and go for OEM Parts... (Parts Land Rover / Engine Oil Costco / Full Oils Change was with site sponsor Opie Oils) Lots on D2N re' what to look for + the www This is worth a look for the basics... SKIP https://www.defender2.net/forum/topic83242.html |
DUCKWORTHS site sponsor have good deal on gen service parts for 2.4 at the moment DEFENDER 90 TDCI XS,
Online or via phone?
I used online might also get a def 2 discount on phone however DEFENDER 90 TDCI XS,
https://www.duckworthparts.co.uk/landrover...lters.html
brought mine in anticipation of a service due later in the year DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Also add the Sump Drain Plug (recently revised spec' + code)
![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
