Home > Puma (Tdci) > Service kits: Britpart vs OEM vs Genuine
Page 2 of 2 <12
Bluest
I would recommend Goldplug magnetic sump plug as you can re-use it each time, just replace the inexpensive aluminium crush washer, which you can get by the 100 on Ebay for pennies.
Or go the whole hog and swap to a Femco drain plug. 2007 110 TDCi Station Wagon XS
Post #942573 15th Feb 2022 1:45pm
stephan123
Hi all,
I plan on doing a basic service on MY15 Defender. One of the jobs is to swap out the fuel filter. I’ve seen contradictory messages about that the new filter needing to be filled with diesel prior to install. Is there a definitive view on the issue?
Post #1061713 2nd Mar 2025 6:45am
LR90XS2011
unsure about the 2.2 but for a 2.4 genuine all in for£100 why wouldn't you.
https://www.duckworthparts.co.uk/landrover...ef08kit24k DEFENDER 90 TDCI XS,
Post #1061714 2nd Mar 2025 7:53am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
No need to do anything with the 2.2. Just replace the fuel filter dry, then prime it by turning the ignition key to position two. The fuel pump will run for 5 to 10 seconds. I usually repeat this cycle eight times.
Post #1061717 2nd Mar 2025 8:31am
BrickBox
That’s not bad at all, considering the fuel filter alone is £50’ish! 2008 2.4 110 Utility Station Wagon XS.
Post #1061718 2nd Mar 2025 8:37am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
The original post is for a 2.4 which does not have a lift pump. You need a tool to prime the lines after changing the fuel filter on a 2.4. The factory tool is $$$ but there are cheap knock offs about. Some come without an air bleed which , of course, is required. Pretty easy to add one but try to get a tool with one already in place.
Post #1061779 2nd Mar 2025 10:25pm
Page 2 of 2 <12
