Home > Puma (Tdci) > Service kits: Britpart vs OEM vs Genuine
MSmith7069
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Had a search but can’t find anything regarding this….
Looking to do a service on my 07 defender puma, first time ever servicing a car myself and she had a big service (service b I think) last year.
Had anyone any views on which kits are good and which are bad, which ones to go with and ones to stay away from. I have seen a Brit part kit with the oil for 70£ delivered so happy to do that and save myself some money there.
Also any tips and things to look for when servicing myself would be great if anyone could share.
If anyone is local to Barnsley and would let me buy some of their time to talk me through it that would be great also Question
Ta
@ADefenderNamedDaisy
Post #942207 12th Feb 2022 6:23pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I use Advanced Factors - sponsor on here. Good price and decent Mahle stuff or equivalent.
For oil I get Castrol from Costco
Post #942225 12th Feb 2022 8:01pm
Bluest
Avoid the Mahle oil filters, they have paper ends instead of plastic. Avoid the Mann oil filters, they have incorrect bore size and don’t seat properly. Genuine are not that expensive and you know it’ll be right. You can probably save a couple of quid by using a Ford branded one for a Transit.
Make sure your air filter box lid is reseated properly after putting a new filter in. It is very easy to miss the hooks under the wing.
Don’t forget to give the prop shafts a bit of grease. 2007 110 TDCi Station Wagon XS
Post #942228 12th Feb 2022 8:11pm
LR90XS2011
not britpart, was once sent a britpart sump plug as part of a Genuine kit!! and it cost me 7 litres of castrol as the seal basically didnt, I now buy ford engine parts from my local ford dealer DEFENDER 90 TDCI XS,
Post #942280 13th Feb 2022 9:37am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
We buy parts for our Rivus workshops from ECP but for service parts find that OEM service items are as cheap if not more so, and you know they are correct.
For non service items there are some good aftermarket cost effective solutions and in many cases they are better than OEM
From my experience Dealers try to keep basic services competitive to stop you using an independent garage, they make their margins on other items and repairs. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #942285 13th Feb 2022 10:18am
ksv
Russia 2007 Defender 110 Puma 2.4 SW Keswick Green
I use oil filter from Purflux, the herringbone form gives more filtration area.
Post #942293 13th Feb 2022 11:52am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I had a britpart kit for the l322 range rover and everything was perfect.
but for the defender i have only ordered parts here and there individually - sump plug which was fine, and oil filter which looks almost identical to the genuine ford one when sat side by side. 1953 80"
1987 mini city e
2011 90"
Post #942374 13th Feb 2022 10:38pm
Genuine gets my vote, because it’s critical parts you don’t want issues to crop up with.
It’s just annoying and a pain to possibly have problems crop up that needn't be a problem.
I would can use Ford Genuine parts at times too, that would be good enough as well.
Engine oil in mine is Fuchs, and axles + T box. WeWillWin🇬🇧🇺🇸
Post #942387 13th Feb 2022 11:38pm
X4SKP
Hello MSmith7069
I Service mine and go for OEM Parts...
(Parts Land Rover / Engine Oil Costco / Full Oils Change was with site sponsor Opie Oils)
Lots on D2N re' what to look for + the www
This is worth a look for the basics...
 SKIP
Post #942417 14th Feb 2022 10:19am
LR90XS2011
DUCKWORTHS site sponsor have good deal on gen service parts for 2.4 at the moment DEFENDER 90 TDCI XS,
Post #942517 14th Feb 2022 10:18pm
kmac
Online or via phone?
Post #942554 15th Feb 2022 11:38am
LR90XS2011
I used online might also get a def 2 discount on phone however DEFENDER 90 TDCI XS,
Post #942555 15th Feb 2022 11:42am
kmac
Thumbs Up
Post #942556 15th Feb 2022 11:43am
LR90XS2011
https://www.duckworthparts.co.uk/landrover...lters.html
brought mine in anticipation of a service due later in the year DEFENDER 90 TDCI XS,
Post #942558 15th Feb 2022 11:45am
X4SKP
Also add the Sump Drain Plug (recently revised spec' + code)
 SKIP
Post #942561 15th Feb 2022 12:34pm
