Home > Maintenance & Modifications > Nugget replacement air filter cartridge |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Hi all
With regards to the Nugget housing, does anyone have a part number or link for a replacement air filter cartridge, Nugget of course sell them but I’m fairly sure it’s a commonly used filter and it seems a little OTT to get one shipped ! Thank you in advance Rich https://www.instagram.com/hustynminepark/ |
12th Feb 2022 1:11pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4149 |
I should say, I haven’t bought one yet, so I guess there’s a small chance it may not be be right, so bear that in mind.
I’ve used Baldwin filters from In Line for my tractor and other machinery for years, so I can vouch for them. They also sell Mann Pro Vents if your ever in need. 2007 110 TDCi Station Wagon XS |
12th Feb 2022 2:28pm |
Thank you Bluest
I will have a look on the air-box lid for the part number. I haven’t changed it in over 18 months, I’m not getting quite the Grunt that I used to from the engine and thought it may be an obvious place to start ! https://www.instagram.com/hustynminepark/ |
12th Feb 2022 2:42pm |
Never hurts to stick fresh filter in. I got the airbox with gauge on it that supposed tell you when filters due to be changed, but not sure I trust it. 2007 110 TDCi Station Wagon XS
12th Feb 2022 5:21pm |
I never have worked out that gauge . It seems to need reseting after every drive ! https://www.instagram.com/hustynminepark/
12th Feb 2022 6:19pm |
The idea is you don’t reset it, you leave it and when it reached the indicator the filter needs changing. You just reset it when a new filter goes in. There’s no harm in resetting it more often, but it’s not needed. 2007 110 TDCi Station Wagon XS
12th Feb 2022 6:24pm |
That makes utter sense , thank you ! https://www.instagram.com/hustynminepark/
12th Feb 2022 6:30pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17206 |
16546-04N00 Wesfil WA830 or A1203 Mahle LX830 Any of the above are available online (as are quality equivalents) for about £10 upwards. |
12th Feb 2022 11:03pm |
Fantastic, thank you Blackwolf
Mahle LX 830 In stock with Opie Oils for £12.95 https://www.instagram.com/hustynminepark/ |
12th Feb 2022 11:19pm |
Yes, it's a bit less disturbing to shop round and get a top-quality filter for around £12 than fork out around £60 for a "Nugget-branded" one.
13th Feb 2022 9:25am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1915 |
thanks for the info blackwolf, I’ve been contemplating fitting a nugget stuff air intake to my 2.2 puma and one of the things I’ve been researching is where an alternative quality but cheaper air filter can be sourced.
I’m thinking of using it without a raised air intake, so best ideas on solutions for connecting to wing intake would be appreciated. I’m just fitting a new BAS intercooler plus BAS intercooler silicon hoses as my intercooler just split. So hoping the addition of a nugget stuff filter box to the bas hoses and intercooler will provide the best cooled airflow into my std map engine. Views appreciated on if it’s worth it on a std map. |
13th Feb 2022 5:06pm |
You will certainly notice the difference provided that you replace the pipework from the wing intake to the filter housing. If you don't replace this, there's little point changing the filter housing.
Assuming that you wish to continue using the standard wing orifice, probably the best option is to use the Nugget upgraded intake pipework from the wing to the filter along with the Nugget filter. The original pipework from the wing to the filter box is a masterclass in inept design, if there are any flaws it doesn't incorporate I really can't think what they are! |
13th Feb 2022 8:15pm |
Thanks blackwolf, looks like that’s going to be my next mod. Once I complete the intercooler installation.
13th Feb 2022 10:31pm |
Regarding the filters that fit in the nugget stuff airbox.
These are the ones quoted by Parts In Motion as equivalent to the ones Blackwolf listed above. PIM are a parts supplier I tend to use for true OEM EGRs etc . Interesting to note is the height of the filter for different manufacturers ranges from 175-178mm and the hole in the bottom, that if I recall correctly, sits on the conical rubber mount in the airbox, ranges from circa 8-10mm, I expect both measurements combine to insure a tight fit 1A FIRST AUTOMOTIVE A60579 ALCO FILTER MD652 AMC Filter IA-385 ASHIKA 20-01-110 BOSCH 1 457 433 275 BREMSI FA2230 CHAMPION W708/606 CLEAN FILTERS MA620 Comline CNS12008, CNS12226 CONTINENTAL 28.0002-0278.2 Coopersfiaam FLI6819 DENCKERMANN A140202 DIAMAX DA2222 DJ PARTS FA1545 Dr!ve+ DP1110.10.0277 DYNAMATRIX DAF830 FIL FILTER HP 4554 A Filtron AM436/1 FLEETGUARD AF1822 Fram CA5369 GCG TURBOS AUSTRALIA RY-A1203 GOODWILL AG 477 HERTH+BUSS JAKOPARTS J1321017 HOFFER 16330, 16449 IAP QUALITY PARTS 121-13042 JAPANPARTS FA-110S JAPKO 20110 JC PREMIUM B21017PR JPN 20F1013-JPN JS ASAKASHI A226J KAGER 12-0220 KAISHIN A226 KAVO PARTS IA--385, IA-385 KLAXCAR FRANCE FA260z KNECHT LX 830 LUCAS FILTERS LFAF359 LYNXauto LA-269 MAGNETI MARELLI 152071758561, eBay Item No. eBay Item No. 154084455530 MAHLE LX 830 MANDO MMF015095 MANN-FILTER C 13 103/1 MAPCO 60542 MASTER-SPORT GERMANY 13103/1-LF-PCS-MS MASUMA MFA-349 MAXGEAR 26-1591 Mchanix NSARF-004 MDR MAF-3110 MEAT & DORIA 16330, 16449 MECAFILTER EL3808 MFILTER A 143 MISFAT RM973 MOTAQUIP VFA669 MULLER FILTER PA579 NIPPARTS J1321017 NPS N132N10, N132N17 OPEN PARTS EAF3408.20 OSSCA 06085 PATRON PF1484 PEMEBLA JAPFA-110S PURFLUX A330 PZL Filters WA30300A QH Talbros WA6112 QUINTON HAZELL QFA0485 RED-LINE 36NI017 RIDEX 8A0378 RYCO A1203 SAKURA Automotive A-1882 Sakura Filters AU FA-1882 SCT - MANNOL SB014 SOFIMA S 7169 A Stark SKAF-0060384 STELLOX 71-02011-SX TECNECO FILTERS AR579-I UFI 27.169.00 UNIFLUX FILTERS XA1842 WE PARTS 16330 WILMINK GROUP WG1216839 Wix Filters WA6112 |
19th Nov 2022 6:50pm |
