Home > Maintenance & Modifications > Nugget replacement air filter cartridge
Page 1 of 6 123456>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi all
With regards to the Nugget housing, does anyone have a part number or link for a replacement air filter cartridge, Nugget of course sell them but I’m fairly sure it’s a commonly used filter and it seems a little OTT to get one shipped !
Thank you in advance
Rich https://www.instagram.com/hustynminepark/
Post #942160 12th Feb 2022 12:11pm
Bluest
Yes, it’s a Nissan small truck filter. The part number is engraved on the airbox lid. You can get a Baldwin (a good make) branded one from In-Line filters in the U.K. you just need to cross references on their site. 2007 110 TDCi Station Wagon XS
Post #942167 12th Feb 2022 1:26pm
Bluest
I should say, I haven’t bought one yet, so I guess there’s a small chance it may not be be right, so bear that in mind.
I’ve used Baldwin filters from In Line for my tractor and other machinery for years, so I can vouch for them. They also sell Mann Pro Vents if your ever in need. 2007 110 TDCi Station Wagon XS
Post #942168 12th Feb 2022 1:28pm
Bluericky
Thank you Bluest
I will have a look on the air-box lid for the part number.
I haven’t changed it in over 18 months, I’m not getting quite the Grunt that I used to from the engine and thought it may be an obvious place to start ! https://www.instagram.com/hustynminepark/
Post #942169 12th Feb 2022 1:42pm
Bluest
Never hurts to stick fresh filter in. I got the airbox with gauge on it that supposed tell you when filters due to be changed, but not sure I trust it. 2007 110 TDCi Station Wagon XS
Post #942195 12th Feb 2022 4:21pm
Bluericky
I never have worked out that gauge . It seems to need reseting after every drive ! https://www.instagram.com/hustynminepark/
Post #942205 12th Feb 2022 5:19pm
Bluest
The idea is you don’t reset it, you leave it and when it reached the indicator the filter needs changing. You just reset it when a new filter goes in. There’s no harm in resetting it more often, but it’s not needed. 2007 110 TDCi Station Wagon XS
Post #942208 12th Feb 2022 5:24pm
Bluericky
That makes utter sense , thank you ! https://www.instagram.com/hustynminepark/
Post #942212 12th Feb 2022 5:30pm
Re: Nugget replacement air filter cartridge
Bluericky wrote:
Hi all
Rich
16546-04N00
Wesfil WA830 or A1203
Mahle LX830
Any of the above are available online (as are quality equivalents) for about £10 upwards.
Post #942254 12th Feb 2022 10:03pm
Bluericky
Fantastic, thank you Blackwolf
Mahle LX 830 In stock with Opie Oils for £12.95 https://www.instagram.com/hustynminepark/
Post #942257 12th Feb 2022 10:19pm
Yes, it's a bit less disturbing to shop round and get a top-quality filter for around £12 than fork out around £60 for a "Nugget-branded" one. Thumbs Up
Post #942278 13th Feb 2022 8:25am
Ianh
thanks for the info blackwolf, I’ve been contemplating fitting a nugget stuff air intake to my 2.2 puma and one of the things I’ve been researching is where an alternative quality but cheaper air filter can be sourced.
I’m thinking of using it without a raised air intake, so best ideas on solutions for connecting to wing intake would be appreciated.
I’m just fitting a new BAS intercooler plus BAS intercooler silicon hoses as my intercooler just split. So hoping the addition of a nugget stuff filter box to the bas hoses and intercooler will provide the best cooled airflow into my std map engine.
Views appreciated on if it’s worth it on a std map.
Post #942332 13th Feb 2022 4:06pm
You will certainly notice the difference provided that you replace the pipework from the wing intake to the filter housing. If you don't replace this, there's little point changing the filter housing.
Assuming that you wish to continue using the standard wing orifice, probably the best option is to use the Nugget upgraded intake pipework from the wing to the filter along with the Nugget filter.
The original pipework from the wing to the filter box is a masterclass in inept design, if there are any flaws it doesn't incorporate I really can't think what they are! Rolling with laughter
Post #942349 13th Feb 2022 7:15pm
Ianh
Thanks blackwolf, looks like that’s going to be my next mod. Once I complete the intercooler installation.
Post #942373 13th Feb 2022 9:31pm
Ianh
Regarding the filters that fit in the nugget stuff airbox.
These are the ones quoted by Parts In Motion as equivalent to the ones Blackwolf listed above. PIM are a parts supplier I tend to use for true OEM EGRs etc .
Interesting to note is the height of the filter for different manufacturers ranges from 175-178mm and the hole in the bottom, that if I recall correctly, sits on the conical rubber mount in the airbox, ranges from circa 8-10mm, I expect both measurements combine to insure a tight fit
1A FIRST AUTOMOTIVE A60579
ALCO FILTER MD652
AMC Filter IA-385
ASHIKA 20-01-110
BOSCH 1 457 433 275
BREMSI FA2230
CHAMPION W708/606
CLEAN FILTERS MA620
Comline CNS12008, CNS12226
CONTINENTAL 28.0002-0278.2
Coopersfiaam FLI6819
DENCKERMANN A140202
DIAMAX DA2222
DJ PARTS FA1545
Dr!ve+ DP1110.10.0277
DYNAMATRIX DAF830
FIL FILTER HP 4554 A
Filtron AM436/1
FLEETGUARD AF1822
Fram CA5369
GCG TURBOS AUSTRALIA RY-A1203
GOODWILL AG 477
HERTH+BUSS JAKOPARTS J1321017
HOFFER 16330, 16449
IAP QUALITY PARTS 121-13042
JAPANPARTS FA-110S
JAPKO 20110
JC PREMIUM B21017PR
JPN 20F1013-JPN
JS ASAKASHI A226J
KAGER 12-0220
KAISHIN A226
KAVO PARTS IA--385, IA-385
KLAXCAR FRANCE FA260z
KNECHT LX 830
LUCAS FILTERS LFAF359
LYNXauto LA-269
MAGNETI MARELLI 152071758561, eBay Item No. eBay Item No. 154084455530
MAHLE LX 830
MANDO MMF015095
MANN-FILTER C 13 103/1
MAPCO 60542
MASTER-SPORT GERMANY 13103/1-LF-PCS-MS
MASUMA MFA-349
MAXGEAR 26-1591
Mchanix NSARF-004
MDR MAF-3110
MEAT & DORIA 16330, 16449
MECAFILTER EL3808
MFILTER A 143
MISFAT RM973
MOTAQUIP VFA669
MULLER FILTER PA579
NIPPARTS J1321017
NPS N132N10, N132N17
OPEN PARTS EAF3408.20
OSSCA 06085
PATRON PF1484
PEMEBLA JAPFA-110S
PURFLUX A330
PZL Filters WA30300A
QH Talbros WA6112
QUINTON HAZELL QFA0485
RED-LINE 36NI017
RIDEX 8A0378
RYCO A1203
SAKURA Automotive A-1882
Sakura Filters AU FA-1882
SCT - MANNOL SB014
SOFIMA S 7169 A
Stark SKAF-0060384
STELLOX 71-02011-SX
TECNECO FILTERS AR579-I
UFI 27.169.00
UNIFLUX FILTERS XA1842
WE PARTS 16330
WILMINK GROUP WG1216839
Wix Filters WA6112
Post #971720 19th Nov 2022 5:50pm
Page 1 of 6 123456>
