Home > Puma (Tdci) > Puma 2.2 fuel filter change + workshop manual
Mickey M
New Zealand 2016 Defender 110 Puma 2.2 SW Indus Silver
Do I need to pre-fill the new fuel filter with Diesel prior to fitting to a 2016 Defender 110SW 2.2l Puma?
Been searching forums and am getting confused - seems to be a variety of opinions. I don't want to stuff anything up.
also - is there a definitive Workshop manual for the Puma Defenders 2.2l? If so, how do I get hold of it? I have the Haynes Defender 2007-2016 workshop manual but it doesn't seem to have been fully updated for the 2.2l.
cheers from NZ....
Post #939329 25th Jan 2022 5:18am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
For a 2.2 Puma Defender there is no need to fill new filter before installing. When swapped over turn on the ignition to position 2 (do not start the engine) and you'll hear the fuel pump in the tank start to whirr. This will pump fuel through the system and fill the new filter / purge the air out (probably about 20 seconds or so). Do this 5 or 6 times to fully purge the air out. Then you should be good to go.
The earlier 2.4 pumas didn't have the lift pump in the tank and require a different method to be followed.
Post #939330 25th Jan 2022 5:50am
Mickey M
terrific, thanks very much Very Happy 2016 Puma 2.2l 110SW
Post #939331 25th Jan 2022 6:07am
Re: Puma 2.2 fuel filter change + workshop manual
Yes -
dgardel wrote:
John Baron wrote:
Hi Guys,
Does anyone know if its possible to download a workshop manual from the LR Topix site? I haven't coughed up any money to go on it yet as it's a little expensive at �250 per year so I was thinking of just buying a day but if I have to sit there and download everything in one go I will save it for a rainy day.
Just interested to know if others have had success with such a download?
Thanks,
John.
https://1drv.ms/f/s!AnHBx4Wc2MJLtxu5Hc2rPgqRNdaz
For 2.4 and 2.2 models (look at the correct MY)
Post #939364 25th Jan 2022 10:25am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Yes, worked fine for me. I was a little worried first, because I heard a gurgling noise even after 5 pump cycles. I did 5 more but it didn't change significantly. It started and ran fine though and next day the noise was gone.
Post #939516 25th Jan 2022 10:30pm
Mickey M
thanks for the info, should be a doddle! 2016 Puma 2.2l 110SW
Post #939534 26th Jan 2022 5:40am
