![]() | Home > Puma (Tdci) > Puma 2.2 fuel filter change + workshop manual |
Mickey M Member Since: 24 Jan 2022 Location: Wellington Posts: 5 ![]() ![]() ![]() |
Do I need to pre-fill the new fuel filter with Diesel prior to fitting to a 2016 Defender 110SW 2.2l Puma?
Been searching forums and am getting confused - seems to be a variety of opinions. I don't want to stuff anything up. also - is there a definitive Workshop manual for the Puma Defenders 2.2l? If so, how do I get hold of it? I have the Haynes Defender 2007-2016 workshop manual but it doesn't seem to have been fully updated for the 2.2l. cheers from NZ.... |
terrific, thanks very much
Yes -
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1094 ![]() ![]() ![]() |
Yes, worked fine for me. I was a little worried first, because I heard a gurgling noise even after 5 pump cycles. I did 5 more but it didn't change significantly. It started and ran fine though and next day the noise was gone. |
thanks for the info, should be a doddle! 2016 Puma 2.2l 110SW
