Home > Maintenance & Modifications > Rear Fuel Tank Guard - on DEF 90 with NAS step |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
To the best of my knowledge a tank guard is not compatible with a NAS step.
If it was a 110 I would suggest a replacement tank with bottom double skinned, however that option is not available from our normal supplier. I would be interested if you find a solution. Brendan |
17th Dec 2018 2:53pm |
dotom Member Since: 04 Feb 2012 Location: Dortmund Posts: 90 |
Hi,
I’ve got a tank guard from Mantec UK. Very good quality but i had to cut away a bit from the sides to make it fit with the NAS Step. The two side bars from the Step to the front did not clear with the tank guard. If you look here http://www.supertweaks.com/image/cache/dat...00x600.jpg you can see what I mean. I got it electroplated for protection. Regards Tom |
17th Dec 2018 6:50pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2162 |
YRM. Ive got one on my 110 with a nas step. Instagram @defender_ventures
Empire Tuning - Agent |
17th Dec 2018 7:55pm |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 258 |
Hi 2010Blackdefender90
The Mantec guard will fit a 90 with a little modification as dotom said but you will also need to remove1-2mm of the aluminium guard around the area of the three fixing bolts on the underside of the cross member to allow the NAS step to fit over it. Click image to enlarge |
17th Dec 2018 8:36pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Click image to enlarge These and here? Think they are the NAS attach,net points too... so think I see what needs modification. |
17th Dec 2018 10:14pm |
Also if you have a rear anti roll bar fitted or especially if it’s an uprated one, I would also consider some spacers 8-10mm under the roll bar bushes, or cut a recessed slot in the guard to make sure the roll bar will not foul on the tank guard.
17th Dec 2018 11:13pm |
defenderroger Member Since: 23 Jan 2022 Location: Lievegem Posts: 2 |
where did you get the tankguard? and does it fit with the folding rear step? it looks like it has a cutout for it or was that modified aswell? thanks in advance! |
23rd Jan 2022 2:31pm |
It'll be from YRM, who make lots of alternative or uprated metal parts. Try here as a starting point:
https://yrmit.co.uk/?s=tank+guard&post...e_aws=true Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd Jan 2022 2:50pm |
Hi
The one in the picture was made by Mantec and I modified it to get it to fit with a NAS step, unfortunately I don’t think you can get them any more. The YRM is a replacement tank cradle opposed to an additional guard. |
23rd Jan 2022 3:09pm |
thanks! too bad the ones from Mantec aren't available anymore.
any other experience with the alu tankguard from Paddock Spares? https://www.paddockspares.com/pm428-def-90...inium.html Thanks. |
23rd Jan 2022 3:56pm |
