Home > Maintenance & Modifications > Rear Fuel Tank Guard - on DEF 90 with NAS step
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Having dinged my tank this weekend, think it's time to invest in a tank guard. Does anyone have a tank guard that fits on / under a NAS Step?
Had a look around, can't seem to find a yes or no answer, sure someone might know.
Thanks
Post #746131 17th Dec 2018 2:12pm
leeds
To the best of my knowledge a tank guard is not compatible with a NAS step.
If it was a 110 I would suggest a replacement tank with bottom double skinned, however that option is not available from our normal supplier.
I would be interested if you find a solution.
Brendan
Post #746134 17th Dec 2018 2:53pm
dotom
Germany 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi,
I’ve got a tank guard from Mantec UK. Very good quality but i had to cut away a bit from the sides to make it fit with the NAS Step. The two side bars from the Step to the front did not clear with the tank guard. If you look here http://www.supertweaks.com/image/cache/dat...00x600.jpg
you can see what I mean.
I got it electroplated for protection.
Regards
Tom
Post #746179 17th Dec 2018 6:50pm
bankz5152
YRM. Ive got one on my 110 with a nas step. Instagram @defender_ventures
Empire Tuning - Agent
Post #746191 17th Dec 2018 7:55pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi 2010Blackdefender90
The Mantec guard will fit a 90 with a little modification as dotom said but you will also need to remove1-2mm of the aluminium guard around the area of the three fixing bolts on the underside of the cross member to allow the NAS step to fit over it.
Post #746200 17th Dec 2018 8:36pm
2010Blackdefender90
These and here? Think they are the NAS attach,net points too... so think I see what needs modification.
Post #746222 17th Dec 2018 10:14pm
Def90
Also if you have a rear anti roll bar fitted or especially if it’s an uprated one, I would also consider some spacers 8-10mm under the roll bar bushes, or cut a recessed slot in the guard to make sure the roll bar will not foul on the tank guard.
Post #746235 17th Dec 2018 11:13pm
defenderroger
Belgium 2008 Defender 90 Puma 2.4 HT Santorini Black
where did you get the tankguard? and does it fit with the folding rear step? it looks like it has a cutout for it or was that modified aswell?
thanks in advance!
Post #939007 23rd Jan 2022 2:31pm
It'll be from YRM, who make lots of alternative or uprated metal parts. Try here as a starting point:
https://yrmit.co.uk/?s=tank+guard&post...e_aws=true Darren
Post #939011 23rd Jan 2022 2:50pm
Def90
Hi
The one in the picture was made by Mantec and I modified it
to get it to fit with a NAS step, unfortunately I don’t think you can
get them any more.
The YRM is a replacement tank cradle opposed to an additional
guard.
Post #939015 23rd Jan 2022 3:09pm
defenderroger
thanks! too bad the ones from Mantec aren't available anymore.
any other experience with the alu tankguard from Paddock Spares?
https://www.paddockspares.com/pm428-def-90...inium.html
Thanks.
Post #939024 23rd Jan 2022 3:56pm
