Home > Puma (Tdci) > 3rd row seat belt points |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 213 |
Hi Craig
Photos of my passenger side 3rd row seat belt fixing. I haven't got one of the reel behind the plastic panel sorry but assume you are asking about the fixing onto the inner wing. Car is 2013 2.2 TDCi. Click image to enlarge Click image to enlarge Click image to enlarge |
19th Jan 2022 12:12pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 193 |
piechipsandpeas thank you
I've managed to get the seatbelt reel fitted on the bracket behind the trim, it's where the other end of the seatbelt anchors to on the body I was unsure about. |
19th Jan 2022 3:38pm |
jmccoy55555 Member Since: 01 Dec 2021 Location: Surrey Posts: 5 |
I’ve got theses to convert my utility…. Not fitted yet. There’s a left and right.
https://yrmit.co.uk/product/lhs-rear-seat-...-defender/ |
19th Jan 2022 6:57pm |
Thanks jmccoy55555, do they come with fitting instructions?, assume the seat belt attaches to the upright the two parallel plates are confusing me though would they not restrict access to tighten the bolt?
Click image to enlarge I found this diagram online looks like there are potentially 2 fitting kits for the seat belt. I have 2 indents in the wheel arch below the rear seats that seem to be guide holes in a similar position to the picture above from piechipsandpeas. Click image to enlarge Would this work? https://www.jgs4x4.co.uk/universal-seat-be...-plate-x2/ |
20th Jan 2022 4:00pm |
I think bolt 7 would go through the tub into the bracket that I referenced that is in turn attached to the chassis. There's also a second bolt which I think just bolts straight through to stop any movement. This ties up with the pictures from piechipsandpeas.
I did come across that plate at some point when I was looking. I think it may be for the side facing seat lap belts. |
21st Jan 2022 8:51am |
Thanks again that makes sense now looking at piechipsandpeas' picture under the wheel arch. I can see how it fits together now.
Click image to enlarge I thought the end of the seatbelt attached to the end of the bracket Click image to enlarge That looks like a much more robust solution than the simple spreader plate which as you say is probably for lap belts. I don't want to mess this up and do it wrong when my children are going to be sitting in them. |
21st Jan 2022 3:28pm |
I did find a parts diagram for it but typically can't find it again now.....
21st Jan 2022 3:53pm |
RaenerPuma2007110 Member Since: 13 Jun 2023 Location: Bournemouth Posts: 39 |
Hi Cragster, how did the seat belt fitting go?
Im doing the same job now on my Puma 2007. Did you use the brac kets in the end? |
13th Jun 2023 11:23am |
This is what my underneath looks like. I guess I need that bracket to give the anchor any kind of strength. Strange you need purchase additional supports (£100 each), when these seats are a standard option.
13th Jun 2023 11:26am |
I didn't, for the MOT I removed the seats so it didn't fail due to lack of seatbelts. I'm enjoying the extra load space without the seats. They are currently sitting wrapped in a sheet in my garage. Not sure if selling them or keeping them in case it hinders the resell value. Would agree that it seems bizarre they weren't fitted as standard. My V5 does say 5 seats though? Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
13th Jun 2023 3:51pm |
