Home > Technical > Aluminum Bolts |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
Unlikely. Then you have all the problems with galling (cold welding) and corrosion. 2007 110 TDCi Station Wagon XS
17th Jan 2022 3:00pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20325 |
No, the shear strength is significantly lower. You need stainless or titanium or factory fit. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
17th Jan 2022 6:54pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2224 |
No you just need galv mild steel.
17th Jan 2022 7:21pm |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 496 |
Ah no worries, I'll go stainless, reason I was asking I see Pro Bolt have anodized black and the price is considerably different between stainless and alu
Thanks for replies folks Shane |
18th Jan 2022 11:04am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1997 |
Remember Duralac is your friend when mixing dissimilar materials such as stainless steel, mild steel and aluminium.
18th Jan 2022 1:15pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
To put things in perspective, grade A2-70 bolts have a tensile strength of 700MPa.
Aircraft grade aluminium, such as 6061 is just over 300MPa. Grade 8.8 is at 830MPa The higher the number in MPa, the stronger is the metal. I would not trust aluminum bolts. Perhaps ok just opening and closing the door, would not fall off but in case of an accident? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
18th Jan 2022 1:27pm |
Yes, definitely need stainless strength upwards.
I used corrosion block on all of mine. Titanium isn’t readily available, I purely mentioned it because it is stronger than Stainless but stainless is perfectly okay. Just not aluminium as that’s the weakest tensile strength. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
18th Jan 2022 3:14pm |
I'll get ordering some Duralac, I'm assembling the body so good to get it on now, Thank you |
19th Jan 2022 12:06pm |
Thanks Dinnu, thats good to know about the numbers i must watch out for that in the future. I was just being a tight fecker |
19th Jan 2022 12:07pm |
I was looking at the price of the titanium bolts Have the stainless on order |
19th Jan 2022 12:08pm |
