Home > Technical > Aluminum Bolts
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Aluminum Bolts
Hi Folks
Quick question for people more knowledgeable then me, Aluminum bolts.... would these be strong enough to use on my door hinges from and rear ?
Shane
Post #938065 17th Jan 2022 2:57pm
Bluest
Unlikely. Then you have all the problems with galling (cold welding) and corrosion. 2007 110 TDCi Station Wagon XS
Post #938066 17th Jan 2022 3:00pm
No, the shear strength is significantly lower. You need stainless or titanium or factory fit. No Guts, No Glory.
Post #938085 17th Jan 2022 6:54pm
Mo Murphy
No you just need galv mild steel.
50 Shades of Pennine Grey
Post #938087 17th Jan 2022 7:21pm
shanecl
Ah no worries, I'll go stainless, reason I was asking I see Pro Bolt have anodized black and the price is considerably different between stainless and alu
Thanks for replies folks Very Happy
Shane
Post #938144 18th Jan 2022 11:04am
Ianh
Remember Duralac is your friend when mixing dissimilar materials such as stainless steel, mild steel and aluminium.
Post #938164 18th Jan 2022 1:15pm
Dinnu
To put things in perspective, grade A2-70 bolts have a tensile strength of 700MPa.
Aircraft grade aluminium, such as 6061 is just over 300MPa.
Grade 8.8 is at 830MPa
The higher the number in MPa, the stronger is the metal.
I would not trust aluminum bolts. Perhaps ok just opening and closing the door, would not fall off but in case of an accident? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938168 18th Jan 2022 1:27pm
Yes, definitely need stainless strength upwards.
I used corrosion block on all of mine.
Titanium isn’t readily available, I purely mentioned it because it is stronger than Stainless but stainless is perfectly okay.
Just not aluminium as that’s the weakest tensile strength. No Guts, No Glory.
Post #938184 18th Jan 2022 3:14pm
shanecl
I'll get ordering some Duralac, I'm assembling the body so good to get it on now, Thank you Very Happy
Post #938314 19th Jan 2022 12:06pm
shanecl
Thanks Dinnu, thats good to know about the numbers i must watch out for that in the future. I was just being a tight fecker Laughing Laughing
Post #938315 19th Jan 2022 12:07pm
shanecl
Just not aluminum as that’s the weakest tensile strength.
I was looking at the price of the titanium bolts Shocked Shocked Have the stainless on order Very Happy
Post #938317 19th Jan 2022 12:08pm
