Home > Maintenance & Modifications > Optimill fuel cap lock seizing.
Co1
Went for diesel yesterday and couldn’t get in! The lock had seized solid. Quick squirt of WD when I got to work freed it up, but I noticed that it does seem to hold a lot of water. Has anyone else found this, and also what is the collective recommendation for lubricating/protecting the lock from seizing? ACF50 or a silicon spray grease be ok?
Post #937658 14th Jan 2022 6:04am
landy andy
I don’t know what I would advise but certainly not wd40 as can make some plastic items swell. If a lock then graphite lub is recommended.
Post #937662 14th Jan 2022 7:17am
The Zee
I use is ABUS PS88 Lubricating Spray, it’s a 50ml spay with a small tube to direct into the lock, after a small squirt, open and close using the key, until smooth, and then follow up with a second squirt.
Just another thing to do before winter frosts happen.
https://www.defender2.net/forum/topic81855.html Zaid-M
www.DefencePhotos.com
Post #937674 14th Jan 2022 10:11am
Smyles_
Denmark
Can't say I ever had that issue with mine over the 2 years whilst in wet central Scotland.
Never lubricated either, but maybe my frequent visits to fuel stations kept it in working order Question Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #937676 14th Jan 2022 10:35am
ChrisDefender
A while back my standard LR fuel cap competely corroded, tried to open it and the lock had all but rusted away inside. After a faff getting it off I replaced with a geuine one. Ever since just to be sure I have pushed a small amount of ACF50 into the lock every couple of months to hopefuly keep the lock free from rust.
Key always seems to go in well.
Post #937688 14th Jan 2022 11:35am
hank
Had my optimill one for years and haven't noticed anything untoward. > 110 XS Double Cab
Post #937692 14th Jan 2022 12:59pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I haven’t had any issues with my Optimill or old genuine cap. I’d personally just put a drop of ACF50 in and work the key in the lock a few times. Repeat now and again. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #937698 14th Jan 2022 1:33pm
Roy5695
I never lock mine so wouldn’t know 😬
I’d rather they siphoned the diesel out than drill a hole in the tank. 😂 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #937760 14th Jan 2022 7:51pm
Co1
That’s a very good point.
Post #937762 14th Jan 2022 8:01pm
