![]() | Home > Maintenance & Modifications > Optimill fuel cap lock seizing. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
I don’t know what I would advise but certainly not wd40 as can make some plastic items swell. If a lock then graphite lub is recommended.
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
I use is ABUS PS88 Lubricating Spray, it’s a 50ml spay with a small tube to direct into the lock, after a small squirt, open and close using the key, until smooth, and then follow up with a second squirt.
Just another thing to do before winter frosts happen. https://www.defender2.net/forum/topic81855.html Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 519 ![]() ![]() |
Can't say I ever had that issue with mine over the 2 years whilst in wet central Scotland.
Never lubricated either, but maybe my frequent visits to fuel stations kept it in working order ![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 459 ![]() ![]() |
A while back my standard LR fuel cap competely corroded, tried to open it and the lock had all but rusted away inside. After a faff getting it off I replaced with a geuine one. Ever since just to be sure I have pushed a small amount of ACF50 into the lock every couple of months to hopefuly keep the lock free from rust.
Key always seems to go in well. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
Had my optimill one for years and haven't noticed anything untoward. > 110 XS Double Cab
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
I haven’t had any issues with my Optimill or old genuine cap. I’d personally just put a drop of ACF50 in and work the key in the lock a few times. Repeat now and again. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I never lock mine so wouldn’t know 😬
I’d rather they siphoned the diesel out than drill a hole in the tank. 😂 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
That’s a very good point.
