Home > Maintenance & Modifications > Topping up the power steering fluid |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1762 |
I thought it was just ATF for the Power steering box, pretty certain that's all I've used
10th Jan 2022 1:53pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4169 |
I think when I looked into this I ended up using Central Hydraulic Fluid, not ATF. I asked Opie Oils, but it was a while ago and I can’t find the email now. 2007 110 TDCi Station Wagon XS
10th Jan 2022 1:55pm |
Spiritbeth Member Since: 24 Mar 2017 Location: Hampshire Posts: 15 |
I had mine topped up last week by my local Landrover independent as I had a graunching noise. He told me that it should be 'the red stuff' that is auto transmission fluid. When filling he said the level should be between the 2 marks when the cap is fully screwed on (not just dipped in). By the way, topping it up has cured the graunching noise. Hope this helps.
10th Jan 2022 2:13pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 967 |
Should be just normal red ATF, top up to level with the engine running. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
10th Jan 2022 3:29pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 453 |
Thanks all, so is the abover Motul as suggested on the Opie site not correct? If not, any siggestions on the preferred ATF, again there are loads to choose from ?
Thank you. |
10th Jan 2022 3:32pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
I use this, only issue is you have to buy 5litres:
https://www.smithandallan.com/products/tra...over-ace-/ Steve 02' 110 TD5 Double Cab Rebuild Thread |
10th Jan 2022 3:33pm |
Excellent, thank you. I guess it will come in useful!
Thanks again |
10th Jan 2022 3:43pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2197 |
Or just buy a 500ml or a litre bottle of ATF from Halfords or your local motor factors like everyone else does 😉
10th Jan 2022 3:54pm |
I’d agree totally with Mo above
Unless you need something more extreme for your artic adventure… Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
10th Jan 2022 4:13pm |
Great, thank you all
Just one last question, do I need fully synthetic? |
10th Jan 2022 4:16pm |
Only if you are adding to fully synthetic fluid already in your system and you don’t want to mix it. Ride like you stole it!!
10th Jan 2022 4:37pm |
OK, thank you. Sometimes I wish I had never checked anything! I dont know what is already in there so I guess I am safer just to change the whole lot, its only 1.6lt I think. What a flaming faff!
Thanks for the help chaps, much appreciated. |
10th Jan 2022 4:42pm |
westie_ Member Since: 06 Apr 2021 Location: Warwickshire Posts: 17 |
I always put ATF or red power steering fluid in it.
They should all do pretty much the same thing at the end of the day 110 Td5 Van |
10th Jan 2022 5:29pm |
I think the reality is that pretty much any oil that says it can be used in hydraulic power steering is probably fine. 2007 110 TDCi Station Wagon XS
10th Jan 2022 6:20pm |
