Home > For Sale & Wanted > [For Sale] Truetrac / Wheel carrier / Bilsteins / 300tdi dri |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
Could you give me more details for the Truetech please. I will take it if it is suitable for my truck.
Many thanks. Mick |
3rd Jan 2022 5:39am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 621 |
It is ten spline for defender axles pre 1994, and Series Land Rovers.
Click image to enlarge |
3rd Jan 2022 6:03pm |
Blue Member Since: 13 Aug 2019 Location: UK Posts: 43 |
Message sent about the Mantec wheel carrier.
Thanks |
3rd Jan 2022 6:28pm |
Do you have a part number? It looks like there are different ones for different axles.
3rd Jan 2022 7:02pm |
Not off hand, as it’s at my workshop. What is your vehicle?
3rd Jan 2022 7:28pm |
Unfortunately it's a bitsa! Whilst its a k reg defender, I believe the axles are from a 200tdi disco. The engine is a 300tdi with R380 and lt230.
I am happy with education on the subject! I am only entering into the engineering side so more than happy to learn. |
3rd Jan 2022 7:56pm |
JOSNOS Member Since: 06 Apr 2012 Location: Bucks Posts: 154 |
PM’d you about the bilstein 2003 TD5 90
5th Jan 2022 9:08am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
Is the trutrac front or rear fitment ?
5th Jan 2022 11:25am |
They are the same unit front and rear - they can be set up for front or rear use depending on requirements.
5th Jan 2022 1:12pm |
Ah, I didn't know they did both. PM sent.
5th Jan 2022 1:20pm |
Oddly they're sold as front or rear fitment 🥴
5th Jan 2022 6:44pm |
Mo, for the second time, the front unit is the same physical unit as the rear.
The difference between front and rear setup is the orientation of the internal worm gears. To swap from front to rear fitment you simply swap the left hand side gears for the right hand side and vice versa. Last edited by Oldowner on 5th Jan 2022 8:03pm. Edited 1 time in total |
5th Jan 2022 8:01pm |
OK thanks The Land Rover 90 - Many are called, few are chosen.
5th Jan 2022 8:02pm |
Gents, I believe this is above my skill level, so unfortunately I will have to pass on this.
Good luck with the sale and to whoever purchases. My best regards Mick |
5th Jan 2022 8:24pm |
