Home > For Sale & Wanted > [For Sale] Truetrac / Wheel carrier / Bilsteins / 300tdi dri
Oldowner
Most of these parts were purchased for a projects that haven’t happened due to lack of time these days.
10 spline Detroit Truetrac ATB centre. Absolutely immaculate, late type stronger 6 bolt housing. Removed from a early 90 after very little use which was converted to 24 spline - I was going to fit it to a Series but never have done. Hard to find and expensive (£600) if you need one! £300
Mantec rear wheel carrier - purchase from DuckWorth Land Rover a couple of years ago. They had a promotion on these Wolf type carriers, this is the rear door (late) version, and includes a set of their spacers for mounting alloys. I’ve never even unwrapped it from the packaging it arrived in let alone fitted it. £150
Set of Bilstein B6 dampers for 98 onwards Defender. Were apparently only used a short time, I never fitted these, purchased off here 18 months ago. I have however sourced the correct Polybush bushes instead of the useless rubber ones Bilstein supply (Have another set of B6’s on my 90) £175
Safari Equip 90 saddle tank, 30litres capacity extra, brand new and never fitted. For Td5 /Puma 90. £200
Complete 300Tdi / R380 / LT230 drivetrain removed complete from an MOT failed 1997 90. I had an idea that I was going to put it all in an early ex military 90. Complete with everything needed including seatbox and floor plates etc. As removed £1000. I can palletise this and ship within UK.
Set of one piece 300tdi 90 driveshafts - perfect for Td5 / pumas fitted with the rubbish two piece shafts. Get rid of the driveshaft clonk for £30 the pair!
Post #936065 2nd Jan 2022 9:09pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Could you give me more details for the Truetech please. I will take it if it is suitable for my truck.
Many thanks.
Mick
Post #936072 3rd Jan 2022 5:39am
Oldowner
It is ten spline for defender axles pre 1994, and Series Land Rovers.
Post #936149 3rd Jan 2022 6:03pm
Blue
2007 Defender 90 Puma 2.4 SW Cairns Blue
Message sent about the Mantec wheel carrier.
Thanks
Post #936154 3rd Jan 2022 6:28pm
Mossberg
Do you have a part number? It looks like there are different ones for different axles.
Post #936161 3rd Jan 2022 7:02pm
Oldowner
Not off hand, as it’s at my workshop. What is your vehicle?
Post #936166 3rd Jan 2022 7:28pm
Mossberg
Unfortunately it's a bitsa! Whilst its a k reg defender, I believe the axles are from a 200tdi disco. The engine is a 300tdi with R380 and lt230.
I am happy with education on the subject!
I am only entering into the engineering side so more than happy to learn.
Post #936178 3rd Jan 2022 7:56pm
JOSNOS
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
PM’d you about the bilstein 2003 TD5 90
Post #936404 5th Jan 2022 9:08am
Mo Murphy
Is the trutrac front or rear fitment ?
50 Shades of Pennine Grey
Post #936421 5th Jan 2022 11:25am
Oldowner
They are the same unit front and rear - they can be set up for front or rear use depending on requirements.
Post #936437 5th Jan 2022 1:12pm
Mossberg
Ah, I didn't know they did both. PM sent.
Post #936440 5th Jan 2022 1:20pm
Mo Murphy
Oddly they're sold as front or rear fitment 🥴
Post #936490 5th Jan 2022 6:44pm
Oldowner
Mo, for the second time, the front unit is the same physical unit as the rear.
The difference between front and rear setup is the orientation of the internal worm gears. To swap from front to rear fitment you simply swap the left hand side gears for the right hand side and vice versa.
Post #936504 5th Jan 2022 8:01pm
Mo Murphy
OK thanks The Land Rover 90 - Many are called, few are chosen.
Post #936505 5th Jan 2022 8:02pm
Mossberg
Gents, I believe this is above my skill level, so unfortunately I will have to pass on this.
Good luck with the sale and to whoever purchases.
My best regards
Mick
Post #936514 5th Jan 2022 8:24pm
