Home > Puma (Tdci) > Exhaust Gas Recirculation Circuit Range/Performance P0404
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
My 2014 110 SW just went into limp mode with engine light on. Turned engine off and back on and it drove the 2miles back home fine.
Plugged into the OBD and P0404 came up. “ Exhaust Gas Recirculation Circuit Range/Performance”
Now this is an ERG fault….. I was at some point going to blank off the ERG.
Real bummer is that I’m meant to be driving to Cornwall for a weeks holiday tomorrow morning.
Any advice how to blunder through this week?
Post #935292 27th Dec 2021 3:06pm
ak615
Had a similar problem with mine a week or so ago, I've put injector and turbo cleaner in the tank and touch wood the fault hasn't re occurred
Post #935298 27th Dec 2021 3:54pm
Landymatt
I had the same problem and cured it by getting a BAS remap via the tool that Pete Bell sends out,
Cheers,
Matt
edit - I had the same fault code appear… possibly the same problem but not necessarily
Post #935301 27th Dec 2021 4:05pm
pilsburypie
Cheers chaps. I am tempted in the near future to get a stage 1 and ERG blank. Just in a bit of a fix for tomorrow. I have cleared the code but not driven since as I’ve had a drink😏
Think my option for the long drive and week away is to take the OBD reader and keep resetting if it comes up. Then on return, look at getting sorted.
Post #935305 27th Dec 2021 4:35pm
DAZ110
Maybe giving it a damm good thrashing up the road might help clear things out. Whistle
Post #935316 27th Dec 2021 7:07pm
pilsburypie
So I’ve cleared the code (and stopped drinking) and took the car for a 2 minute drive round the block. Engine light has not come back on and it drives fine.
So plan to drive to Cornwall tomorrow morning as planned from the Midlands….. 3.5 hours of mainly motorway. So if needing a blow out is what is required, that should do it. Taking the reader with me to reset if needed.
Never had breakdown cover as I’ve always been very self sufficient….. anyone know if I do end up incapacitated in Cornwall if you can just sign up to AA or the likes right then and there and get towed back under their cover? Or do you have to be a member before breaking down?!!!
Post #935319 27th Dec 2021 7:46pm
If you don’t already, consider running Millers diesel additive as soon as you can.
It isn’t a miracle product but may well help in your situation in due course.
I use it all the time, and it will run better and cleaner too. Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #935329 27th Dec 2021 10:16pm
pilsburypie
Cheers. I might see if I can pick some up tomorrow. For me at the moment it’s all about getting through this next week. If I’m in limp mode on the M5 I’m in the Censored !
Post #935331 27th Dec 2021 10:43pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I agree with DAZ110. A good long run getting everything heated up and cleaned out does wonders with the 2.2. It doesn´t like short journeys at all. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTs,
Recaro CSs, anorak, wellingtons
Post #935343 28th Dec 2021 7:04am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I’m sure my 2.2 runs much better since I started putting Redex in the tank (not tried Millers) & totally agree it needs a good blast down the motorway now & again to give it a good clean through. Premium diesel seemed to have a positive effect too, but I’ve settled on standard diesel & a splash of Redex. It’s quite subjective though, in my mind my engine is sparkling clean inside!
Post #935344 28th Dec 2021 7:28am
Same system as me, regular diesel and Millers. Stick to that permanently.
Typically 99% of the time use Esso too, not that it’s that critical.
Diesel techs commonly swear by it, I was skeptical at first but now use permanently.
K9F on here started me off on it.
Being parked up periods of time and short trips definitely do cake things things up. Chillin In The Backwoods🇬🇧🇺🇸
Post #935436 28th Dec 2021 6:47pm
pilsburypie
So you recon there’s a difference between supermarket fuels and Esso? There’s certainly a difference in price…. £5-6/tank.
Would you believe that I popped into Aldi this morning to pick up a few basics to last us the first day of holiday…. They only had diesel redex twin pack…. So bought some and banged a bottle in my full tank.
Now sitting in a holiday home in Cornwall after an uneventful journey and no engine warning light. Fingers crossed for the rest of the week.
Post #935438 28th Dec 2021 7:03pm
Glad you made it all good. Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #935443 28th Dec 2021 7:52pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Prevention is better than cure with your 2.2 especially if you only do short journeys. I would recommend a fuel cleaning additive every 6months and then use Millers on every fill.
DPF’s are crazy, burn three times the fuel to save half the particulates. Get rid of it and let your engine perform at its best Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #935478 29th Dec 2021 7:25am
pilsburypie
Back from Holiday. Many hundreds of miles covered and no issues. 2 full tanks with that redex went through, so hopefully that has done some sort of cleaning.
At least the fix was removal of the fault code. One of the easier ones for the time being at least…
Post #936112 3rd Jan 2022 1:51pm
