Home > Td5 > TD5 Heater Fan
Page 2 of 2 <12
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Hi Dorsetsmith
Thank you.
Shame you are so far away! I could have got you to fix it Rolling with laughter
Post #933806 16th Dec 2021 10:00am
Tank
dorsetsmith wrote:
heater switch first stage swathes ground with resister - stage two or flat out bypasses resister to the motor
check that you good ground the switch
black wire with black spade on the end and male spade lug on the switch lever
Is there a 60 amp fuse under the drivers seat for the fan? Could that be the problem?
Post #934325 19th Dec 2021 10:29pm
dorsetsmith
Link 5 60 amps in the under seat fuse box is the supply to starter relay and ignition switch
Post #934331 19th Dec 2021 11:08pm
Tank
Ah, well that works then as the car drives and starts fine, so its not that. Thanks that saved me the faff of taking the seat out to have a look (i have fancy seats Very Happy )
Will keep trying!
Duncan
Post #934357 20th Dec 2021 10:29am
Tank
OK still no blower fan!
Is there a way of putting power to the fan via the connections in the engine bay to see if it will spin up?
Dunk
Post #936107 3rd Jan 2022 12:34pm
freddie206
United Kingdom 2006 Defender 110 Td5 HT Belize Green
Hi Dunk,
I wanted to do the same thing a few years ago so I bought a Sealey PP1 Auto Probe. It’s ideal for powering up 12v components.
Hope that helps
Fred
Post #936108 3rd Jan 2022 12:51pm
dorsetsmith
at the plug purple and green wire needs to have 12 volts + to battery - with the ign switched to pos ii
Green and slate gray wire and green and yellow are switched to ground i.e. battery - this cared out with heater speed control
a Digital Multimeter so you can read dc voltage and Continuity and Resistance and Test wiring good tool
Post #936117 3rd Jan 2022 2:45pm
Page 2 of 2 <12
