Home > Td5 > TD5 Heater Fan |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
Hi Dorsetsmith
Thank you. Shame you are so far away! I could have got you to fix it |
16th Dec 2021 10:00am |
Link 5 60 amps in the under seat fuse box is the supply to starter relay and ignition switch
19th Dec 2021 11:08pm |
Ah, well that works then as the car drives and starts fine, so its not that. Thanks that saved me the faff of taking the seat out to have a look (i have fancy seats )
Cheers Will keep trying! Cheers Duncan |
20th Dec 2021 10:29am |
OK still no blower fan!
Is there a way of putting power to the fan via the connections in the engine bay to see if it will spin up? Cheers Dunk |
3rd Jan 2022 12:34pm |
freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 90 |
Hi Dunk,
I wanted to do the same thing a few years ago so I bought a Sealey PP1 Auto Probe. It’s ideal for powering up 12v components. Hope that helps Fred |
3rd Jan 2022 12:51pm |
at the plug purple and green wire needs to have 12 volts + to battery - with the ign switched to pos ii Green and slate gray wire and green and yellow are switched to ground i.e. battery - this cared out with heater speed control a Digital Multimeter so you can read dc voltage and Continuity and Resistance and Test wiring good tool |
3rd Jan 2022 2:45pm |
