Home > In Car Electronics > trying to fit new rear speakers on my 2014 110
Swerni
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Auto Corris Grey
Embarrassed to ask, but being ham fisted I need to.
How do I remove the rear panels to fit the speaks?
Post #932963 9th Dec 2021 12:02pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
take the handful of fixings out (unscrew the centre part and then lever out the remaining collar/plug), and then remove the panel.
From memory it's a bit of a tight fit, and you have to pull the panel out from the bottom. it'll bend about a bit on the way out, but doesn't get damaged.
Refitting is the reverse, and you have to put the top in first as it lips under the panel above.
Post #932965 9th Dec 2021 12:19pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I pulled the top panel around the rear corner windows first then there are 3 clips that using a trim removal tool they popped out then panel can be removed to allow you to clean behind and fit new speakers. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #932971 9th Dec 2021 1:33pm
Stacey007
They are awkward, it could be the carpet if you have removed all the fittings (from memory one fitting is hidden by carpet)
You can just about see where the fittings are on this picture showing my set up.
Post #932982 9th Dec 2021 4:30pm
jpboost
Slightly off topic, but Stacey007, what was the reason for surface mounting the crossovers?
Was there not enough space behind, or did you want them on display?
I'm looking to upgrade mine soon, and trying to plan ahead where I'll put everything.
Post #932983 9th Dec 2021 4:47pm
Swerni
Thanks folks.
All sorted !
Post #933046 10th Dec 2021 8:12am
Stacey007
As for the tweeters I thought they look too good to hide, although to be fair they are pretty hidden when in...
The front focal ES100K ELITE K2 tweeter box's are velcroed to the inside of the speaker openings behind the dash.
Thumbs Up
Post #933051 10th Dec 2021 9:36am
