Home > Wheels & Tyres > Maxxis Trepador M-8060 security
Stevo5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Now that my Defender has gone all ‘Big Foot’ I’m needing to up the security a bit.
The wheels are the Maxxis Trepadors in 35/12.50/16 M-8060 and they ain’t cheap to replace (£354.00 each from what I can see).
LRD Security sell a spare wheel security cover but it says it’s only for LR alloys and clearly these are a tad bigger.
Any ideas/suggestions?
Post #932420 4th Dec 2021 4:06pm
Motorbike chain? Darren
Post #932431 4th Dec 2021 5:09pm
Rabbitwabbit
United Kingdom 1997 Defender 110 300 Tdi CSW Stornoway Grey
I have simply put a locking wheel nut on mine - as per the main roadwheels
Post #932432 4th Dec 2021 5:12pm
markb110
Someone on ebay used to make a spare wheel lock for alloy wheels.
I bought one then modified the mount on the standard wheel carrier then notched a circler ally plate i had kicking around, neoprene backed so not to scratch the wheel.
Not sure if it is still available.
Post #932446 4th Dec 2021 7:54pm
Siwynne
I run similar wheels and turned an ally spindle and bolted it to the wheel carrier. The photo shows the plate for boost alloys but it now has a bigger one set further in for the Mach 5 alikes on mine.
I can swap wheels at any time and the spindle caters for both
Getting one turned at an engineering shop wouldn’t be too expensive
Post #932451 4th Dec 2021 9:13pm
Stevo5
Thanks for the tips so far guys, the vehicle itself has a fair few security additions but the wheels now are a big target for thieves-especially the spare one.
Post #932453 4th Dec 2021 9:24pm
The Zee
In addition to a lock/padlock holding the wheel to the wheel carrier, might a plain un-decorated wheel and tyre cover help. Since it would provide some visual protection, if they can't see it, they can't want it. I know some will say the determined thief will not care, but taking your precious spare wheel & tyre off display may prevent the opitunist? Zaid-M
www.DefencePhotos.com
Post #932477 5th Dec 2021 11:26am
Ianh
I think they may know what’s under the cover by looking at any of the other 4 wheels
Post #932485 5th Dec 2021 12:46pm
How do you find them on the road? I’d suggest a cable lock as well, but be careful it doesn’t cause abrasion that’s the issue so needs padding or something similar. No Guts, No Glory.
Post #932514 5th Dec 2021 4:46pm
Stevo5
Too early to tell as I’ve only driven it fully loaded with all the kit they took off (a lot). Felt heavier and a lot more tyre and wind noise. It certainly puts a smile on your face that’s for certain!
Post #932521 5th Dec 2021 5:39pm
Looks good. Thumbs Up No Guts, No Glory.
Post #932526 5th Dec 2021 5:59pm
Stevo5
Can anyone recommend some good reliable sturdy locking wheel nuts please?
I know its not a rock solid solution but hopefully enough to deter. I had to buy aftermarket nuts for my old M3 after all my wheels were nicked one night-they used OEM locking wheel nuts (my locking nut was still in the car) and ledft it on wooden blocks. Had the slowest M3 in the UK that day
Post #932529 5th Dec 2021 6:09pm
