![]() | Home > Wheels & Tyres > Maxxis Trepador M-8060 security |
Motorbike chain? Darren
Rabbitwabbit Member Since: 31 Mar 2021 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
I have simply put a locking wheel nut on mine - as per the main roadwheels
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
Someone on ebay used to make a spare wheel lock for alloy wheels.
I bought one then modified the mount on the standard wheel carrier then notched a circler ally plate i had kicking around, neoprene backed so not to scratch the wheel. Not sure if it is still available. ![]() Click image to enlarge ![]() Click image to enlarge |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 594 ![]() ![]() |
I run similar wheels and turned an ally spindle and bolted it to the wheel carrier. The photo shows the plate for boost alloys but it now has a bigger one set further in for the Mach 5 alikes on mine.
![]() Click image to enlarge I can swap wheels at any time and the spindle caters for both Getting one turned at an engineering shop wouldn’t be too expensive |
Stevo5 Member Since: 26 Mar 2021 Location: East of England Posts: 42 ![]() ![]() ![]() |
Thanks for the tips so far guys, the vehicle itself has a fair few security additions but the wheels now are a big target for thieves-especially the spare one.
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
In addition to a lock/padlock holding the wheel to the wheel carrier, might a plain un-decorated wheel and tyre cover help. Since it would provide some visual protection, if they can't see it, they can't want it. I know some will say the determined thief will not care, but taking your precious spare wheel & tyre off display may prevent the opitunist? Zaid-M
www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2239 ![]() ![]() |
I think they may know what’s under the cover by looking at any of the other 4 wheels |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
How do you find them on the road? I’d suggest a cable lock as well, but be careful it doesn’t cause abrasion that’s the issue so needs padding or something similar. WeWillWin🇬🇧🇺🇸
Too early to tell as I’ve only driven it fully loaded with all the kit they took off (a lot). Felt heavier and a lot more tyre and wind noise. It certainly puts a smile on your face that’s for certain!
Looks good.
Can anyone recommend some good reliable sturdy locking wheel nuts please?
I know its not a rock solid solution but hopefully enough to deter. I had to buy aftermarket nuts for my old M3 after all my wheels were nicked one night-they used OEM locking wheel nuts (my locking nut was still in the car) and ledft it on wooden blocks. Had the slowest M3 in the UK that day |
