![]() | Home > Technical > P0504-62 (2F) Brake switch A/B correlation |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Turned out to be a very easy fix. There are two brake switches, and one had come loose from its very flimsy mounting. Roaming around 🇳🇴🇨ðŸ‡
hey if it works, it works. thanks mate! Roaming around 🇳🇴🇨ðŸ‡
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 ![]() ![]() ![]() |
Are these the switches? ![]() Click image to enlarge Just had this code on both my 110s within a week of each other, one at 18000 miles, the other at 76000 miles. Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
I've just been reminded that sometimes you should start with the basics..
After messing about swapping these switches from our third defender, the brakes mysteriously started binding on all four wheels, only releasing after being left for an hour or so. So I then discovered that although the pushrod retracts fully when the switch is loose, the retraction of the pushrod part is fixed when the switch is twisted into place. I had pushed the pedal down when I fitted one of the switches, so the pushrod was too long and was stopping the brake pedal returning fully. ![]() ![]() Click image to enlarge I then viewed the live values using my BAS tool and found that one of the brake switches didn't show as open when the pedal was depressed. Then I got my camera out to video the brake lights, which turned out not to be operating. Then I checked the brake light fuse, which was blown on both 110s showing the fault. Fuse changed, fault code gone! ![]() Click image to enlarge ![]() Click image to enlarge Later that day, I'm needing my trailer again. Hitched on, half a mile later, DSC light on again. Then I realised I towed the trailer with both 110s recently and that's why both were affected. By a fault with the trailer brake lights. Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
