Home > Wheels & Tyres > 255/85 advice
Page 1 of 5 12345>
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
255/85 advice
Hi,
Looking to change my tyres on my defender 90 (standard height)
Currently got 235/85/16’s on my sawtooths which are et20?!?! Would i be able to change to 255/85 without much alterations??
Any images would be great! Cant seem to find any sawtooths with 255/85’s fitted!!
Post #928967 7th Nov 2021 8:54pm
Ianh
I run 265/75’s on my 16 inch sawtooth’s , the 255/85’s will be taller but narrower so you should be able to fit with no problem at all. Noting for balancing you may wish to look at beads rather than standard weights as the 255/85’s are generally only in an MT.
A minor adjustment of the stops to prevent rubbing on full steering lock may be required but that’s all.
PS. If your sawtooth’s are factory they will be ET20 , it will be stamped on the inner side of the wheel.
Post #928969 7th Nov 2021 9:12pm
Anderzander
Excellent tyre size !!
Post #928970 7th Nov 2021 9:18pm
donmacn
Since I first saw pics of them, I’ve fancied these, but so far they haven’t been available as All Terrain’s, just M/T and my useage just doesn’t justify that.
Anyone know if they’re available in A/T yet? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #928975 7th Nov 2021 9:36pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
255s really look the business. I have them on dual-finish et33 with no problem.
On Sawtooths they will be great as they have the same et20,6 as wolfs but are half an inch wider.
 Roaming around 🇳🇴🇨🇭
Post #928977 7th Nov 2021 9:39pm
markb110
My last 110 on Wolf wheels with a two inch lift
And stuffed into the wheel arch
Post #928978 7th Nov 2021 9:41pm
Anderzander
Now on these …
Post #928984 7th Nov 2021 10:10pm
255/85 for me, I’ve ran them for a good 4 years now. On Boost rims but great tyre size.
I prefer them to 235’s.
I have never lost traction off-road with them, mud, take it all. Just go easy in the wet like all MT’s.
I run on MT’s all the time, lots on road but I only do around 6 - 8k a year.
Dynabeads are good.
Dynabeads and weights work too, if you have no weights or don’t want any. A bit more Dynabeads in weight maybe useful.
See Blackwolfs posts on here regarding Dynabeads and application quantity.
Mine has the standard recommended amount but you can go somewhat higher in weight. TheThunderRolls🇬🇧🇺🇸
Post #928990 7th Nov 2021 10:40pm
AJC
i have 255/85's on mine, i do have a 2 inch lift but they'd be fine on standard ride height
Post #929082 8th Nov 2021 5:53pm
wdef34
Hello, the only A/T 255/85 i am aware of is the toyo m55 (ultra hi quality commercial tyre), if you have a kidney to spare...
Post #929107 8th Nov 2021 6:58pm
donmacn
Thanks for that - but you’re not kidding about the cost!! $360 each!
I’ll keep hoping. Donald
in the past..
Post #929141 8th Nov 2021 9:32pm
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
Hi DeeEss! On 255 it looks really good Thumbs Up I see on this pic that your Def is registered in Switzerland. Any issue with the tecnhical inspection in CH with your 255?
Thank you for your info
Grüss Lolo
Post #929641 13th Nov 2021 9:07pm
Simboii
Think the 255/85’s are the way forward, just look right with the height and not too wide!
Anderzander wrote:
On spacers??
Post #929736 14th Nov 2021 8:25pm
Angus_Beef
Grüss Lolo
Hi Lolo, no problem at MfK with 255/85R16 as long as they are on an approved 6.5 or 7 inch rim 👍🏼 Roaming around 🇳🇴🇨🇭
Post #929738 14th Nov 2021 8:41pm
lolo
Thank you DeeEss Thumbs Up
Post #929740 14th Nov 2021 8:44pm
Page 1 of 5 12345>
