Home > Maintenance & Modifications > Battery clamp fixings |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17463 |
At a guess I would say that the thread is almost certainly an ISO M8 x 1.25mm (coarse series), i.e., a "standard" M8, but I haven't actually checked. If so replacing the ultra-long factory special bolt (YJH500020) with something like an M8 x 1.25 x 25mm SHC or hex-flange-head screw would be very straightforward.
If I get the chance later on I will have a look. |
5th Nov 2021 10:47am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
I am almost certain the battery retainers on my Td5 (threaded tent peg type things) are M6x1.00 as i replaced the nuts with wingnuts.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
5th Nov 2021 1:02pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 486 |
m6 x1 and 25mm thread length
5th Nov 2021 1:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
Thank you for the replies, mines a 2.4 Puma.
No idea as to if the battery tray is the same as a TD5 though. I seem to remember they were more along the lines of a coarse thread on mine like Blackwolf suggested. It’s just one of those jobs that I may as well do, just didn’t get around to it. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Nov 2021 5:41pm |
Update on this I checked mine today to be sure in the end as I was a bit confused as to the a definitive answer.
On mine 2.4 Puma they are M6 x 22mm L exc head with standard pitch. I expect 25mm L May fit as well though but I’d go like for like. Max fixing head / flange dia is 16mm of flat surface on the clamp area. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Nov 2021 2:38pm |
Fitted today, M6, 22mm Long. Standard thread fits perfectly.
I fitted Ti drilled hex bolts with flanges and a little corrosion block on threads. A 1/4” screwdriver style driver and appropriate socket fits well and good access too. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Mar 2022 9:46pm |
