Home > Maintenance & Modifications > Battery clamp fixings
Bit of a long shot and to save me having to check. Whistle
Does anyone know the thread type, dia, and length of the battery clamp to battery tray fixings?
I remember someone on here replaced them as the extended versions can catch on things or get in the way.
On mine due to live battery outputs I’d rather replace those two factory fixings as there is a risk if the battery shifted the two could contact so I have insulated the clamp fixing for some time.
Something like torx button head fixings would be ideal or something along those lines, then they are well out of the way and just as secure. I always carry torx bits and a cheap socket set anyway.
Suggestions welcome. Thumbs Up No Guts, No Glory.
Post #928549 4th Nov 2021 8:00pm
At a guess I would say that the thread is almost certainly an ISO M8 x 1.25mm (coarse series), i.e., a "standard" M8, but I haven't actually checked. If so replacing the ultra-long factory special bolt (YJH500020) with something like an M8 x 1.25 x 25mm SHC or hex-flange-head screw would be very straightforward.
If I get the chance later on I will have a look.
Post #928615 5th Nov 2021 10:47am
rallysteve
I am almost certain the battery retainers on my Td5 (threaded tent peg type things) are M6x1.00 as i replaced the nuts with wingnuts.
Post #928634 5th Nov 2021 1:02pm
Linds Hanson
m6 x1 and 25mm thread length
Post #928640 5th Nov 2021 1:40pm
Thank you for the replies, mines a 2.4 Puma.
No idea as to if the battery tray is the same as a TD5 though.
I seem to remember they were more along the lines of a coarse thread on mine like Blackwolf suggested.
It’s just one of those jobs that I may as well do, just didn’t get around to it. No Guts, No Glory.
Post #928668 5th Nov 2021 5:41pm
Update on this I checked mine today to be sure in the end as I was a bit confused as to the a definitive answer.
On mine 2.4 Puma they are M6 x 22mm L exc head with standard pitch.
I expect 25mm L May fit as well though but I’d go like for like.
Max fixing head / flange dia is 16mm of flat surface on the clamp area. No Guts, No Glory.
Post #930594 21st Nov 2021 2:38pm
Fitted today, M6, 22mm Long. Standard thread fits perfectly.
Very Happy
I fitted Ti drilled hex bolts with flanges and a little corrosion block on threads.
A 1/4” screwdriver style driver and appropriate socket fits well and good access too. No Guts, No Glory.
Post #944986 7th Mar 2022 9:46pm
