Home > Puma (Tdci) > Our defender has issues idling and accelerating. |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 298 |
Have a quick search for VCV valve (Volume Control Valve).
It’s a not uncommon on the 2.4, not sure about the 2.2. |
3rd Nov 2021 5:47pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1969 |
Lots on here if you do a search on vcv.
If you have no diagnostic trouble codes it points more to the vcv If replacing one here is the process https://www.defender2.net/forum/topic80710.html?highlight=vcv Also look here https://bellautoservices.co.uk/store/defen...our-valve/ As with first link you can get away without steps 7 and 8, starts lumpy but go for run and should settle down. Very doable at hone, not technical, just a little cramped but first post advises on what tools to use. Vcv can be obtained cheaper from pf Jones |
3rd Nov 2021 7:27pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Very easy job, just unplug the VCV from the loom, unplug the vacuum hose (push the collar in while pulling the hose out) and the fuel line via the quick release to get more room and then it's just two 5mm Allen bolts. You'll probably have to reuse the Allen bolts because the two in the kit are too long. It'll really change the way it drives. Mine was a basket case before, I had to stop every few miles to switch it off to reset it.
Part: https://d2pautoparts.com/products/diesel-f...2940090260 |
3rd Nov 2021 7:50pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20263 |
Consider bridging or replacing the clutch switch as well.
If you decide to bridge you’ll need 2 pole J.P.T. connectors, on a Puma the circuit must stay closed if you chose to bridge it which you can do with connectors. Alternatively, replace the clutch switch it’s self, the VCV is a likely candidate as suggested. VCV tends to create stalling, espaially when revs drop off or when cold and poor performance and hesitation. A rough idle when cold, perhaps not noticeable though in your country. The clutch switch failiure tends to exert a jerkiness on gear changes, revs pull away just as gear is engaged without drive input and things like that. |
3rd Nov 2021 8:33pm |
345rover Member Since: 03 Nov 2021 Location: Cayman Islands Posts: 2 |
Done some work this wknd. Took apart the dash an ecu to get at the wiring harness. It was completely corroded and now am waiting on a replacement for that. In the meantime will check up on the VCV. Update again once the wiring harness is in.
8th Nov 2021 2:01pm |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 |
+1 for the VCV.
Also try cleaning the the connections of CHT (Cylinder Head Temp Sensor) with electrical contact cleaner. I had an issue with mine when it was warm and after cleaning those it was back to normal. |
8th Nov 2021 6:57pm |
