Home > Maintenance & Modifications > Puma Wipers |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1791 |
seizing spindles / rack
9th Oct 2021 10:37am |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
Meaning... pry dash back a bit and lubricate and free up or dash out and replace?
9th Oct 2021 10:49am |
If you search I think it was Blackwolf who wrote an excellent 'how to' set of instructions, I can't remember if he covered it there or someone else in another post, but remember to mark the 12pm point on the spindles, withdraw the rack slowly and carefully, re grease everything and free off spindles if you're not replacing them, then make sure the marks are at 6pm point when it goes back together so the spindle has a fresh set of teeth.
HTH Keith |
9th Oct 2021 11:02am |
Yes, have seen that excellent write up, I am wondering more what can be accomplished without removing the dash.
Going to try freeing up and lubricating from the outside first as described. |
9th Oct 2021 11:16am |
Mines a left hooker so I was able to just slacken everything off enough to access the motor, remove the motor and then service the rack - but I didn't have the column or instruments to deal with.
I think I've read on here others have managed the same in a right hand drive. Good luck! |
9th Oct 2021 11:39am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2250 |
Most likely you'll need to replace the wiper boxes and the drive cable. Bearmach do OEM wiper boxes which are indeed the real thing without the LR boxes and prices.
9th Oct 2021 1:32pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 819 |
As above most likely wheel boxes....There is also an aftermarket option...
Click image to enlarge |
9th Oct 2021 4:59pm |
So copious amount of 3in1 to the outer spindles and a lot more force than I was comfortable with and all working.
Kept them going for a good hour with repeated sprays of 3in1. There is a definite hard click in the action so clearly going to need disassembly... another day. Thank you for all the advice. |
9th Oct 2021 6:32pm |
Click image to enlarge Pack some silicon grease in to back of the rubber boot that's over the end help to stop water being driven in Last edited by dorsetsmith on 10th Oct 2021 1:02pm. Edited 1 time in total |
10th Oct 2021 8:55am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2066 |
Like dorsetsmith after oiling spindles I seal with grease but use red rubber grease under the rubber boots as its rubber friendly.
Also if your rubber spindle boots are deteriorating you can get replacement ones off a well know auction site. |
10th Oct 2021 11:28am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 627 |
The click is usually the spindle moving in and out with the change of direction. You can remove the back of the wheel box and bend the tang in slightly to take out the freeplay in the spindle. But on a Puma by the time you’ve stripped the dash out you might as well fit new OEM wheel boxes, and flip the rack cable over to present the unworn side to the spindles. I have fitted design and development wheel boxes and they are very good. |
11th Oct 2021 11:37am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Stiff1
I suspect you have achieved a delay in the inevitable (but well done) keep 'feeding' them with lubricant and you may get through winter. I could not free up mine recently, so took on the replacement big job and lesson learnt, regular maintenance Penetrating Oil / ACF50 down spindle and grease in rubber cap on the Spindle. https://www.defender2.net/forum/topic57900-15.html Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
11th Oct 2021 11:53am |
