Home > Maintenance & Modifications > For those who aren’t married. |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 825 |
I guess it maybe cheeper to get married Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
7th Oct 2021 4:55pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3433 |
By the hub bolt pattern, looks like it is made for a Series, not a Defender axle. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
7th Oct 2021 5:01pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4219 |
That could be true, they do a lot of other series stuff. 2007 110 TDCi Station Wagon XS
7th Oct 2021 5:18pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
It can’t be THAT expensive!! |
7th Oct 2021 5:28pm |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 |
If you think getting married is expensive, wait until you get divorced. |
7th Oct 2021 5:42pm |
7th Oct 2021 6:17pm |
Yep divorce costs more than the marriage. You loose things you never knew you owned. Searching for my first Defender...and started just as Covid hit, so talk about timing.
7th Oct 2021 7:31pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
Looks like the Tibus unit that G wagens can have.
7th Oct 2021 7:42pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
Ooooh its a Portal axle? I thought it was a tool for manufacturing a steel rim, right now I understand why you guys are saying its not going to be cheap.
Their Defendery bits on on: https://www.designdevelopmenteng.co.uk/sho...c115811253 'Reassuringly expensive' but not outragous? 2005 Td5 90 XS 1989 V8 110 CSW |
7th Oct 2021 8:38pm |
Curious about these ~ anyone any experience?
Snap Fit Security Bonnet Bush Click image to enlarge https://www.designdevelopmenteng.co.uk/sho...c115811253 |
8th Oct 2021 8:25am |
I've got a set to fit but not had chance yet. Darren
8th Oct 2021 10:29am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
From what I have seen of their engineering, the stuff from these guys is pretty good. I have one of their modified Disco2 ACE valve blocks to fit on my Disco (not fitted yet) and the workmanship is excellent. I am also lead to understand (by them) that they did much of the engineering behind the LOF one-piece adaptor shaft as well.
If they are now making bolt-on portal kits it is a very interesting development, but don't expect them to be remotely cheap either in price or quality. The general problem with bolt-on portals is that the axle isn't really strong enough for the portals. Tibus has done quite a lot of work to overcome this and it will be interesting to see how D&D address the problem. |
8th Oct 2021 11:24am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 918 |
I have their disc brake conversion brackets on the series and the quality of the machining work is very very nice.
Bryan is a great chap to deal with too, their customer service I can't fault. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
8th Oct 2021 4:37pm |
